[MPICH] null termination of MPI_Comm_get_name ?
Rajeev Thakur thakur at mcs.anl.gov
Wed Jul 11 14:27:25 CDT 2007
Since that test itself is setting null-terminated names, it will get back
null-terminated names. The only question is whether the pre-set name for
MPI_COMM_SELF will be null-terminated. I think if you are calling
MPI_Comm_get_name in C it would be.
Rajeev
> Date: Wed, 11 Jul 2007 17:52:11 +0200
> From: Toon Knapen <toon.knapen at fft.be>
> User-Agent: Thunderbird 1.5.0.12 (Windows/20070509)
> Mime-Version: 1.0
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] null termination of MPI_Comm_get_name ?
> Hi all,
> In noticed that the test in test/mpi/comm/commname.c in mpich2-1.0.5p4
> compares what is returned by MPI_Comm_get_name (nameout) using the
> function 'strcmp'.
> However by using 'strcmp', the test relies on nameout[rlen] being a
> null-terminator.
> In my understanding of the standard however this is not the case. It is
> documented that the length of the name in C may only be
> MPI_MAX_OBJECT_NAME to be able to store the null terminator.
> So I would suggest to use 'strncmp' in the test. This has the extra
> advantage that the test also tests the rlen value that is returned by
> MPI_Comm_get_name (which is currently not the case).
> toon
