[MPICH] FLASH IO over Jaguar
    Yu, Weikuan
    wyu at ornl.gov
    Tue Jul 10 07:24:25 CDT 2007
Hi, Rob,
> Thanks Weikuan.  How did you determine these numbers?  I'll
> add them to the benchmark.
They were initially based on the numbers in the code for CHIBA. But I
used these numbers based on fairly extensive tests.
-- HDF5 parameters. I checked on differences choice of HDF5 parameters,
there are not much differences.
-- Collective buffer size. Default 4MB is too small. Increasing it to
16MB+ provided good performance improvement. Beyond 32MB, there is not
much gains.
-- Number of IO Aggregators. Perferred to be 512 or 1K. Too many of them
can be detrimental. This is not set in the patch because people may run
with nprocs < 1K.
BTW, in terms of IO aggregators and collective buffer size, the same
seems to be true with NAS BT-IO over Cray XT.
Weikuan Yu
http://ft.ornl.gov/~wyu
