[MPICH] slow IOR when using fileview
Yu, Weikuan
wyu at ornl.gov
Tue Jul 3 07:56:18 CDT 2007
The concept of buffertype is implicitly linked with a concrete memory
buffer, it is valid to report its contiguity. However, the filetype is
more abstract a feature describing a process's view of a file and its
own segments, so its contiguity needs to be reflected more accurately
with associated process and the intended file range. In addtion, the
buffertype describes about the data source, while the filetype describes
the data sink. So they really do not intersect.
However, I think your idea points to the correct direction. Something
like the following is what I have in mind for a process to test the
contiguity of a file within a range:
ADIOI_Filetype_iscontig(filetype, offset, len, &filetype_is_contig);
This may avoid sharing the contiguity checking routine between datatype
and filetype.
ADIOI_Datatype_iscontig(filetype, &filetype_is_contig);
Comments?
--Weikuan
> In fact, this I/O pattern should trigger ADIO_WriteContig()
> for best result. I suggest one more test should be given here
> for checking if the intersection of the buffertype and
> filetype is contiguous. If yes,
> ADIO_WriteContig() is called. Here, the intersection
> operation will involve the current file position. I don't
> know how complicate can this implementation be.
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Wei-keng Liao
> Sent: Tuesday, July 03, 2007 1:04 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: RE: [MPICH] slow IOR when using fileview
> I checked the ROMIO source for this particular access pattern.
> At first, a few words about the access pattern.
> 1) MPI_Type_create_subarray() creates the file access regions like
> file: |----------|----------|----------| .... |----------|
> P0 P1 P2 P7
> Each segment is of size 10MB.
> 2) There is no overlapped, interleaved, or non-contiguous
> access across
> all processes. Every file access is a single contiguous
> write request.
> 3) Write buffer is also contiguous. The write amount is 10
> MB, same across
> all MPI processes.
> 4) The effect of using this file type should be the same as using
> explicit file offset without file type.
> In ROMIO source file ad_write_coll.c, in function
> ADIOI_GEN_WriteStridedColl(), ADIOI_Datatype_iscontig() is
> called in line
> 141 to check if the file type is contiguous and it returns 0.
> That means the file type is not contiguous. In general, this
> is true, since the file type is applied to the entire file
> space repeatedly. Therefore, in line 153, ADIO_WriteStrided()
> is called, instead of ADIO_WriteContig() in line 150. So,
> data sieving is performed by default in ADIO_WriteStrided()
> which chops the 10 MB write into 20 512KB chunks. For each
> chunk, a read-modify-write is carried out.
> Wei-keng
> On Mon, 2 Jul 2007, Yu, Weikuan wrote:
> >> If the independent
> >> access is used instead, I don't know why each write is
> divided into
> >> 512 KB chunks and locking is ever needed to guaranteed the atomic
> >> access of the 10 MB contiguous file range. For this
> particular access
> >> pattern, ROMIO should not do read-modify-write at all.
> > 512KB is the default buffer size for data sieving. So with
> 512KB buffer size, each process is only able to write out
> 512KB data in each call of ADIOI_GEN_WriteStrided. For 10MB,
> this results in 20 iterations of write_all(), 40 fcntl()
> total. crayPat indicates that fcntl() takes 88% of the total
> Wall clock time with fileview, 0% w/o fileview.
> > --Weikuan
