[MPICH] -machinfile and -localonly options to mpiexec
Andrea Di Blas
andrea at soe.ucsc.edu
Mon Jul 2 18:10:40 CDT 2007
hi rajeev,
I guess the problem is that I'm still using 1.0.5p3. I'll upgrade.
thanks a lot!
andrea
Andrea Di Blas UCSC
School of Engineering
Tel: (831) 459 4193 Fax: (831) 459 4829
On Sat, 30 Jun 2007, Rajeev Thakur wrote:
> > 1) the -localonly option seems not to be supported anymore.
> > using -host <local host> should be the same, right?
> -localonly is supported by the mpiexec of the SMPD process manager, not MPD.
> You could use -host instead.
> > 2) mpiexec with the -machinefile <myFile> option hangs the
> > machine - no
> > messages. the file format of the machine file list seems to
> > be correct.
> > any idea of why this is? has the option been replaced/modified?
> This should have been fixed in the 1.0.5p4 patch release. Are you using this
> version?
> Rajeev
