[MPICH] slow IOR when using fileview
Robert Latham
robl at mcs.anl.gov
Mon Jul 2 16:13:43 CDT 2007
On Mon, Jul 02, 2007 at 03:41:56PM -0500, Wei-keng Liao wrote:
> Can you let me know where in ROMIO this fcntl() is called? I wonder why it
> is called when I used a fileview and not when fileview is not used.
Hi Wei-keng and others:
ROMIO calls fcntl to claim/release locks in the routine
ADIOI_Set_lock. ADIOI_Set_lock is the main function for
the ADIOI_WRITE_LOCK, ADIOI_READ_LOCK, and ADIOI_UNLOCK macros.
Why are these lock/unlock calls being made when you use a fileview?
As Rajeev said yesterday, you are passing in a type that is
logically contiguous, but has a type signature such that ROMIO treats
it as a noncontiguous type.
When you don't use a file type, ROMIO treats the operation as
contiuous and makes no fcntl calls.
If you make ROMIO use ADIOI_GEN_ReadStrided_naive somehow, would that
get better performance? Looks like you can get that by disabling data
sieving.
Rajeev already suggested increasing cb_buffer_size. What if you also
increased ind_wr_buffer_size and ind_rd_buffer_size?
==rob
Rob Latham
Mathematics and Computer Science Division A215 0178 EA2D B059 8CDF
Argonne National Lab, IL USA B29D F333 664A 4280 315B
