[MPICH] slow IOR when using fileview
Yu, Weikuan
wyu at ornl.gov
Mon Jul 2 13:51:11 CDT 2007
Hi, Wei-keng,
The problem apprears to lie with the costly system call over Cray XT. In
this case, it is fcntl(). While fcntl() has been avoided for file
systems like PVFS/PVFS2, and its cost is also negligible on a
linux-based lustre file system, it does seem to be costly on Cray XT. In
addtion, given the fact that the MPI-IO source code for Cray XT lies
with Cray, we need to work with Cray to get a possible fix to this as
soon as we can. In the mean time, you may try to avoid the use of
write_all or explore some other alternative.
Thanks again for your report,
--Weikuan
> -----Original Message-----
> From: Wei-keng Liao [mailto:wkliao at ece.northwestern.edu]
> Sent: Monday, July 02, 2007 2:02 PM
> To: Yu, Weikuan
> Cc: mpich-discuss at mcs.anl.gov; Canon, Richard Shane; Hodson,
> Stephen W.; Renaud, William A.
> Subject: RE: [MPICH] slow IOR when using fileview
> Weikuan,
> I found this problem when I ran IOR benchmark. I extracted a
> simpler code to reproduce this situation (it is provided in
> my earlier post on this
> list.) The 10MB is used by this simpler code in order to show
> the performance difference I mentioned. It does not mean I
> used only 10 MB in my IOR runs.
> Wei-keng
> On Mon, 2 Jul 2007, Yu, Weikuan wrote:
> > Thanks for reporting this. I got a similar report from a ticket you
> > filed at ORNL. I am following up with this thread for folks'
> > collective attention on this behavior.
> > While there are many differences between Cray XT and other
> platforms
> > with a linux-based Lustre file system or PVFS, such as caching and
> > comm library etc, this performance difference between write_all and
> > write_at_all does not seem to be directly related to them. Besides,
> > running collective IO with IOR may not seem to be an
> advisable thing
> > with the intended pattern of 10MB per file? Could you
> detail a little
> > more on the actual need/intention of a file view here, or a breif
> > description of intended access pattern in your apps?
> > Weikuan Yu, Ph.D
> > Future Technologies & Technology Integration Oak Ridge National
> > Laboratory Oak Ridge, TN 37831-6173
> > Email: wyu at ornl.gov
> > http://ft.ornl.gov/~wyu/
> >> From: owner-mpich-discuss at mcs.anl.gov
> >> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Wei-keng Liao
> >> Sent: Saturday, June 30, 2007 3:03 AM
> >> To: mpich-discuss at mcs.anl.gov
> >> Subject: [MPICH] slow IOR when using fileview
> >> I am experiencing slow IOR performance on Cray XT3 when using
> >> fileview option. I extract the code into a simpler version
> >> (attached). The code compares two collective writes:
> >> MPI_File_write_all and MPI_File_write_at_all. The former
> uses an MPI
> >> fileview and the latter uses explicit file offset. For both cases,
> >> each process writes 10 MB to a shared file, contiguously,
> >> non-overlapping, non-interleaved. On the Cray
> >> XT3 with Lustre file system, the former is extremely
> slower than the
> >> latter. Here is an output for using 8 processes:
> >> 2: MPI_File_write_all() time = 4.72 sec
> >> 3: MPI_File_write_all() time = 4.74 sec
> >> 6: MPI_File_write_all() time = 4.77 sec
> >> 1: MPI_File_write_all() time = 4.79 sec
> >> 7: MPI_File_write_all() time = 4.81 sec
> >> 0: MPI_File_write_all() time = 4.83 sec
> >> 5: MPI_File_write_all() time = 4.85 sec
> >> 4: MPI_File_write_all() time = 4.89 sec
> >> 2: MPI_File_write_at_all() time = 0.02 sec
> >> 1: MPI_File_write_at_all() time = 0.02 sec
> >> 3: MPI_File_write_at_all() time = 0.02 sec
> >> 0: MPI_File_write_at_all() time = 0.02 sec
> >> 6: MPI_File_write_at_all() time = 0.02 sec
> >> 4: MPI_File_write_at_all() time = 0.02 sec
> >> 7: MPI_File_write_at_all() time = 0.02 sec
> >> 5: MPI_File_write_at_all() time = 0.02 sec
> >> I tried the same code on other machines and different file systems
> >> (eg.
> >> PVFS), and timings for both cases were very close to each
> other. If
> >> anyone has access to a Cray XT3 machine, could you please
> try it and
> >> let me know?
> >> Thanks.
> >> Wei-keng
