[MPICH] slow IOR when using fileview
Rajeev Thakur
thakur at mcs.anl.gov
Sun Jul 1 17:05:46 CDT 2007
Try setting the hint cb_buffer_size to 10485760.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Wei-keng Liao
> Sent: Sunday, July 01, 2007 3:25 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: RE: [MPICH] slow IOR when using fileview
> I tried different datatype constructors. Compared to the case without
> using MPI_File_setview(), the results are:
> MPI_Type_create_subarray() ---- much slower
> MPI_Type_indexed() ---- much slower
> MPI_Type_vector() with explicit offset in setview ---- much slower
> MPI_Type_contiguous() with explicit offset in setview ---- same
> MPI_BYTE with explicit offset in setview ---- same
> The MPICH is version 2-1.0.2. I cannot test newer versions on that
> machine.
> Wei-keng
> On Sun, 1 Jul 2007, Rajeev Thakur wrote:
> > Can you see what happens if you use type_indexed instead of
> type_subarray?
> > Rajeev
> >> Sent: Saturday, June 30, 2007 2:03 AM
> >> Subject: [MPICH] slow IOR when using fileview
> >> I am experiencing slow IOR performance on Cray XT3 when using
> >> fileview
> >> option. I extract the code into a simpler version (attached).
> >> The code
> >> compares two collective writes: MPI_File_write_all and
> >> MPI_File_write_at_all. The former uses an MPI fileview and
> >> the latter uses
> >> explicit file offset. For both cases, each process writes
> 10 MB to a
> >> shared file, contiguously, non-overlapping, non-interleaved.
> >> On the Cray
> >> XT3 with Lustre file system, the former is extremely
> slower than the
> >> latter. Here is an output for using 8 processes:
> >> 2: MPI_File_write_all() time = 4.72 sec
> >> 3: MPI_File_write_all() time = 4.74 sec
> >> 6: MPI_File_write_all() time = 4.77 sec
> >> 1: MPI_File_write_all() time = 4.79 sec
> >> 7: MPI_File_write_all() time = 4.81 sec
> >> 0: MPI_File_write_all() time = 4.83 sec
> >> 5: MPI_File_write_all() time = 4.85 sec
> >> 4: MPI_File_write_all() time = 4.89 sec
> >> 2: MPI_File_write_at_all() time = 0.02 sec
> >> 1: MPI_File_write_at_all() time = 0.02 sec
> >> 3: MPI_File_write_at_all() time = 0.02 sec
> >> 0: MPI_File_write_at_all() time = 0.02 sec
> >> 6: MPI_File_write_at_all() time = 0.02 sec
> >> 4: MPI_File_write_at_all() time = 0.02 sec
> >> 7: MPI_File_write_at_all() time = 0.02 sec
> >> 5: MPI_File_write_at_all() time = 0.02 sec
> >> I tried the same code on other machines and different file
> >> systems (eg.
> >> PVFS), and timings for both cases were very close to each
> >> other. If anyone
> >> has access to a Cray XT3 machine, could you please try it and
> >> let me know?
> >> Thanks.
> >> Wei-keng
