[MPICH] 'make testing' on mpich2-1.0.5
William Gropp gropp at mcs.anl.gov
Mon Jan 15 10:54:40 CST 2007
What is the symptom of your problem?  It sounds like MPICH2 is
properly built.
Bill
On Jan 13, 2007, at 9:43 PM, Deji Akingunola wrote:
> I was unable to run a program I'm working with on mpich2-1.0.5 (the
> program works fine with mpich-1.2.7 and openmpi). So I decided to run
> make testing to see if it was caused by a build problem. All the tests
> passed except the cmdtests, which fails inconsistently, at one
> instance it fails with 7 errors, and at another time with 1 error. The
> most verbose error is as posted below, I'll appreciate if someone can
> point out to me what I could possibly be doing wrong.
> Thanks. (The whole make testing log and the test summary are attached)
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070115/1ccfa43d/attachment.htm>
