[MPICH] 'make testing' on mpich2-1.0.5
Deji Akingunola dakingun at gmail.com
Sat Jan 13 21:43:15 CST 2007
I was unable to run a program I'm working with on mpich2-1.0.5 (the
program works fine with mpich-1.2.7 and openmpi). So I decided to run
make testing to see if it was caused by a build problem. All the tests
passed except the cmdtests, which fails inconsistently, at one
instance it fails with 7 errors, and at another time with 1 error. The
most verbose error is as posted below, I'll appreciate if someone can
point out to me what I could possibly be doing wrong.
Thanks. (The whole make testing log and the test summary are attached)
/usr/bin/mpiexec -n 3 ./stdintest <in.txt 2>err.txt 1>out.txt
agape_mpdman_0 (recv_dict_msg 549):recv_dict_msg: errmsg=::
  mpdtb:
    /usr/bin/mpdlib.py,  549,  recv_dict_msg
    /usr/bin/mpdman.py,  1227,  handle_console_input
    /usr/bin/mpdlib.py,  743,  handle_active_streams
    /usr/bin/mpdman.py,  436,  run
    /usr/bin/mpd,  1408,  launch_mpdman_via_fork
    /usr/bin/mpd,  1325,  run_one_cli
    /usr/bin/mpd,  1199,  do_mpdrun
    /usr/bin/mpd,  614,  handle_console_input
    /usr/bin/mpd,  286,  runmainloop
    /usr/bin/mpd,  255,  run
    /usr/bin/mpd,  1470,  <module>
    mpd_cli_app=./stdintest
    cwd=/home/deji/rpmbuild/BUILD/mpich2-1.0.5p1/test/commands
Did not see entire input file (only 0 lines)
/usr/bin/mpiexec ./stdintest2 <in.txt 2>err.txt 1>out.txt
make[2]: Entering directory
`/home/deji/rpmbuild/BUILD/mpich2-1.0.5p1/test/commands'
/usr/bin/mpicc -c stdintest2.c
/usr/bin/mpicc -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
-fstack-protector --param=ssp-buffer-size=4 -m32 -march=i386
-mtune=generic -fasynchronous-unwind-tables -m32 -Wl,-z,noexecstack
-o stdintest2 stdintest2.o  -lpthread      -lrt
make[2]: Leaving directory
agape_mpdman_0 (handle_console_input 1311): cannot send stdin to client
/usr/bin/mpicc -Dtestname=\"foo\" ./rtest.c
/usr/bin/mpicc -Dtestname='"foo bar"' ./rtest.c
/usr/bin/mpicxx -Dtestname=\"foo\" ./rtestx.cxx
/usr/bin/mpicxx -Dtestname='"foo bar"' ./rtestx.cxx
/usr/bin/mpif77 -Dtestname=\"foo\" ./rtestf.F
/usr/bin/mpif77 -Dtestname='"foo bar"' ./rtestf.F
 Found 1 errors
make[1]: Leaving directory
Deji
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070113/4d25f98f/attachment.bin>
Type: text/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070113/4d25f98f/attachment-0001.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070113/4d25f98f/attachment.obj>
