[MPICH] FreeBSD and the ch3:smm channel?
Steve Kargl
sgk at troutmask.apl.washington.edu
Wed Jan 31 17:24:43 CST 2007
On Wed, Jan 31, 2007 at 04:49:59PM -0600, Darius Buntinas wrote:
> First, what's the execution time of some of the codes you generally run on
> those machines for the different configurations?
My single processor rip code take roughly 15 minutes of CPU time
to perform a computation. The ripmp code does that same computation
with mpich2 and using ch3:sock reports about 39 seconds when spread
across the 24 effective cpus. Wall clock is roughly 41-42 seconds.
There is very little communication (ie master sends initial data
to slaves and then sits and waits for a single send from each slave).
It may be just some start-up latency that I now see with nemesis.
> Just to check message latency and bandwidth you can run netpipe that comes
> with the MPICH2 distibution:
> #substitute ${MPICH2_SRCDIR} with the location of the source directory
> cp ${MPICH2_SRCDIR}/test/mpi/basic/GetOpt.* .
> cp ${MPICH2_SRCDIR}/test/mpi/basic/netmpi.c .
> #assuming MPICH2 bin is in your path
> mpicc Getopt.c netmpi.c -o netmpi
> #just to see whether its running on the same node or not
> mpiexec -n 2 hostname
node10:kargl[246] mpiexec -n 2 hostname
node10.cimu.org
node10.cimu.org
> mpiexec -n 2 ./netmpi
Some selective output:
0: node10.cimu.org
1: node10.cimu.org
Latency: 0.000000749
Sync Time: 0.000002478
Now starting main loop
0: 0 bytes 1048576 times --> 0.00 Mbps in 0.000000754 sec
1: 1 bytes 1048576 times --> 8.44 Mbps in 0.000000904 sec
10: 20 bytes 163950 times --> 181.48 Mbps in 0.000000841 sec
20: 63 bytes 157433 times --> 534.17 Mbps in 0.000000900 sec
30: 194 bytes 175328 times --> 1430.46 Mbps in 0.000001035 sec
40: 764 bytes 93751 times --> 3780.93 Mbps in 0.000001542 sec
50: 2047 bytes 43727 times --> 5420.73 Mbps in 0.000002881 sec
60: 6146 bytes 26032 times --> 7221.15 Mbps in 0.000006493 sec
70: 24572 bytes 8300 times --> 7731.53 Mbps in 0.000024247 sec
80: 65535 bytes 1847 times --> 7298.06 Mbps in 0.000068510 sec
90: 196610 bytes 914 times --> 8200.11 Mbps in 0.000182926 sec
100: 786428 bytes 256 times --> 6540.57 Mbps in 0.000917347 sec
110: 2097151 bytes 51 times --> 6542.41 Mbps in 0.002445581 sec
120: 6291458 bytes 22 times --> 6638.42 Mbps in 0.007230639 sec
130: 25165820 bytes 6 times --> 6914.70 Mbps in 0.027766923 sec
140: 67108863 bytes 3 times --> 6939.06 Mbps in 0.073785186 sec
> Try this for the different configurations, and with both processes on the
> same node and on different nodes.
netmpi may be the app I need for some network.
> It's possible that your codes aren't that sensitive to latency or
> bandwidth, so you won't see much of a difference. Also, if certain
> processes communicate more than others, it would be beneficial, especially
> with nemesis, to put them on the same node. By default, mpd will
> distribute them in round-robin, so process 0 and 1 will be on separate
> nodes.
My colleague's code is the heavier communicator. After my last email,
I received the following from him concerning his code and nemesis.
Steve,
recompiling seems to have worked well! Now it runs much faster on multiple
cores on the same node! It seems to be working, Thanks a lot.
F
|Franco,
|Can you recompile all of your codes to test the shared memory
|method? I think you may need to link against the new
|libraries to get this to work.
|Steve
If he's happy, I'm happy.
Thanks for your help. If you would like some future testing
of nemesis in a development version of mpich2, feel free to
drop me a note.
Steve
