[MPICH] MPDBOOT Problems
Rajeev Thakur
thakur at mcs.anl.gov
Wed Jan 31 16:04:29 CST 2007
You need to use the mpdcheck utility to debug the problem as described in
the installation guide. The networking environment is probably not set up
right.
Rajeev
_____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Luiz Mendes
Sent: Wednesday, January 31, 2007 3:25 PM
To: mpich-discuss
Subject: [MPICH] MPDBOOT Problems
Hi all,
I have installed MPICH2 in a shared folder outside home dir.
And i shared this folder with other 6 computers in a cluster.
Well, when i try to run mpdboot it doesnt work for more than 2 PCS.
When i try mpdboot -n 2 -f <hosts file> it performs ok, however when i try
with 3 PCS or more i doesnt works and record an error message like this
following message :
mpdboot_computer1 (handle_mpd_output 374): failed to ping mpd on computer1;
recvd output={}
It is strange because with 2 PCS, this one computer1 works, and now with 3
it doesnt work anymore.
Furthermore, i touch and set permission to .mpd.conf files in every node of
the cluster, and i set the secretwork too..
What is going on with MPDBOOT?
Thanks in Advance,
Luiz Mendes
UFJF
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070131/31ce289e/attachment.htm>
