[MPICH] mpich2-1.0.5, ch3:ssm, pathscale on opteron
Darius Buntinas
buntinas at mcs.anl.gov
Fri Jan 26 16:13:48 CST 2007
Hi Miguel,
I'm attaching a patch to nemesis to have it read the
MPICH_INTERFACE_HOSTNAME variable. Please let me know if it works, or if
you have any trouble with this.
Darius
On Fri, 26 Jan 2007, Miguel Oliveira wrote:
> Anthony Chan wrote:
>> http://email.osc.edu/pipermail/mpiexec/2006/000718.html
>> This suggests that -tranform-hostname was meant for MPICH1 originally.
>> But newer version of mpiexec from OSC gets it to work with MPICH2/pmi.
>> http: //www.osc.edu/~pw/mpiexec/index.php
>> http: //www.osc.edu/~pw/mpiexec/index.php#Changes
>> Are you using the latest OSC mpiexec, version 0.82 ?
>> A.Chan
> I'm using the latest version (0.82).
> I've also checked that the environment variable MPICH_INTERFACE_HOSTNAME is
> being set properly which it is.
> It looks like mpiexec is doing what is supposed to but ch3:nemesis is not
> honoring this.
> Any ideas?
> All the best,
> MAO
Index: src/mpid/ch3/channels/nemesis/nemesis/net_mod/tcp_module/tcp_module_init.c
RCS file: /home/MPI/cvsMaster/mpich2-01/src/mpid/ch3/channels/nemesis/nemesis/net_mod/tcp_module/tcp_module_init.c,v
retrieving revision 1.32
diff -u -r1.32 tcp_module_init.c
--- src/mpid/ch3/channels/nemesis/nemesis/net_mod/tcp_module/tcp_module_init.c 8 Dec 2006 20:53:36 -0000 1.32
+++ src/mpid/ch3/channels/nemesis/nemesis/net_mod/tcp_module/tcp_module_init.c 26 Jan 2007 22:10:27 -0000
@@ -6,6 +6,13 @@
#include "tcp_module_impl.h"
+static int getSockInterfaceAddr( int myRank, char *ifname, int maxIfname);
+/* We set dbg_ifname to 1 to help debug the choice of interface name
+ used when determining which interface to advertise to other
+ processes in getSockInterfaceAddr.
+static int dbg_ifname = 0;
static MPID_nem_queue_t _free_queue;
MPID_nem_queue_ptr_t MPID_nem_module_tcp_free_queue = 0;
@@ -52,7 +59,7 @@
struct sockaddr_in temp;
char s[255];
- int len2 = 255;
+ const int len2 = 255;
int low_port, high_port;
nodes[grank].desc = socket(AF_INET, SOCK_STREAM, 0);
@@ -97,8 +104,8 @@
MPIU_ERR_CHKANDJUMP2 (ret == -1, mpi_errno, MPI_ERR_OTHER, "**listen", "**listen %s %d", strerror (errno), errno);
/* Put the key (machine name, port #, src , dest) with PMI */
- ret = gethostname(s, len2);
- MPIU_ERR_CHKANDJUMP2 (ret == -1, mpi_errno, MPI_ERR_OTHER, "**sock_gethost", "**sock_gethost %s %d", strerror (errno), errno);
+ mpi_errno = getSockInterfaceAddr(MPID_nem_mem_region.rank, s, len2);
+ if (mpi_errno) MPIU_ERR_POP(mpi_errno);
#ifdef TRACE
fprintf(stderr,"[%i] ID : %s_%d_%d_%d \n",MPID_nem_mem_region.rank,s,
ntohs(nodes[grank].sock_id.sin_port),grank,MPID_nem_mem_region.rank);
@@ -424,4 +431,61 @@
return MPI_SUCCESS;
+#undef FUNCNAME
+#define FUNCNAME getSockInterfaceAddr
+#undef FCNAME
+#define FCNAME MPIDI_QUOTE(FUNCNAME)
+ char *ifname_string;
+ int mpi_errno = MPI_SUCCESS;
+ /* Check for the name supplied through an environment variable */
+ ifname_string = getenv("MPICH_INTERFACE_HOSTNAME");
+ if (!ifname_string) {
+ /* See if there is a per-process name for the interfaces (e.g.,
+ the process manager only delievers the same values for the
+ environment to each process */
+ char namebuf[1024];
+ MPIU_Snprintf( namebuf, sizeof(namebuf),
+ "MPICH_INTERFACE_HOSTNAME_R%d", myRank );
+ ifname_string = getenv( namebuf );
+ if (dbg_ifname && ifname_string) {
+ fprintf( stdout, "Found interface name %s from %s\n",
+ ifname_string, namebuf );
+ fflush( stdout );
+ else if (dbg_ifname) {
+ fprintf( stdout,
+ "Found interface name %s from MPICH_INTERFACE_HOSTNAME\n",
+ ifname_string );
+ fflush( stdout );
+ int len;
+ /* If we have nothing, then use the host name */
+ mpi_errno = MPID_Get_processor_name(ifname, maxIfname, &len );
+ ifname_string = ifname;
+ /* If we didn't find a specific name, then try to get an IP address
+ directly from the available interfaces, if that is supported on
+ this platform. Otherwise, we'll drop into the next step that uses
+ the ifname */
+ else {
+ /* Copy this name into the output name */
+ MPIU_Strncpy( ifname, ifname_string, maxIfname );
+ fn_exit:
+ return mpi_errno;
+ fn_fail:
+ goto fn_exit;
