[MPICH] Re: Problems with allreduce
Luiz Mendes
luizmendesw at gmail.com
Tue Jan 23 18:36:47 CST 2007
Hi all, Rajeev
Well it is still early in Argonne now, here is 10pm lol
I was testing some reads, and i see that Collective read_all perform slower
times to complete than read only operation. Is this correct? or it would be
notable only in great files?
Below, it follows the code:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <mpi.h>
#include <string.h>
#define FILESIZE 1048576
#define INTS_PER_BLK 16
int main(int argc, char **argv)
int *buf, rank, nprocs, nints, bufsize;
double tempo_total, tempo1, tempo2, tempo;
MPI_File fh;
MPI_Datatype filetype;
MPI_Init(&argc,&argv);
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
bufsize = FILESIZE/nprocs;
buf = (int *) malloc(bufsize);
nints = bufsize/sizeof(int);
MPI_File_open(MPI_COMM_WORLD, "datafile", MPI_MODE_RDONLY,
MPI_INFO_NULL, &fh);
MPI_Type_vector(nints/INTS_PER_BLK, INTS_PER_BLK,INTS_PER_BLK*nprocs,
MPI_INT, &filetype);
MPI_Type_commit(&filetype);
MPI_File_set_view(fh, INTS_PER_BLK*sizeof(int)*rank, MPI_INT,
filetype, "native", MPI_INFO_NULL);
tempo1=MPI_Wtime();
MPI_File_read_all(fh, buf, nints, MPI_INT, MPI_STATUS_IGNORE);
tempo2=MPI_Wtime();
tempo=tempo2-tempo1;
printf("\nPrinting Time of current process--> foi %.10f",tempo);
MPI_Allreduce(&tempo, &tempo_total, 1, MPI_DOUBLE,
MPI_MAX,MPI_COMM_WORLD);
if(rank==0)
printf("\nThe longest time is %.10f\n",tempo_total);
MPI_File_close(&fh);
MPI_Type_free(&filetype);
free(buf);
MPI_Finalize();
return 0;
Thanks.
Luiz.
2007/1/23, Rajeev Thakur <thakur at mcs.anl.gov>:
> Unless dimensao is 1, the Allreduce won't work because the input and
> output buffers are single element doubles (not arrays).
> Rajeev
> *From:* Luiz Mendes [mailto:luizmendesw at gmail.com]
> *Sent:* Tuesday, January 23, 2007 6:10 PM
> *To:* mpich-discuss
> *Cc:* Rajeev Thakur
> *Subject:* Re: [MPICH] Re: Problems with allreduce
> Hi all, Rajeev
> I correct this, and i made some simplifications, and the problems appears
> to be caused by the fact of i add double variable declarations.
> It is very strange. Some light to this?
> Thanks
> Luiz
> > Where have you allocated space for arquivo_nome?
> > Rajeev
> > *From:* owner-mpich-discuss at mcs.anl.gov [mailto:
> > owner-mpich-discuss at mcs.anl.gov] *On Behalf Of *Luiz Mendes
> > *Sent:* Tuesday, January 23, 2007 5:05 PM
> > *To:* mpich-discuss
> > *Subject:* [MPICH] Re: Problems with allreduce
> > Discard variable "tempo", without this continue getting error.
> > thanks
> > 2007/1/23, Luiz Mendes <luizmendesw at gmail.com>:
> > > Hi all, i am with a problem in operation MPI_Allreduce.
> > > The code is the following below:
> > > int main(int argc, char *argv[])
> > > int opcao, dimensao,nome_tamanho, processo, num_procs;
> > > int coluna, contador_bytes, contador_bytes_parcial, interacao,
> > > contador_total_bytes;
> > > char *palavra = NULL, *arquivo_nome;
> > > char *arquivo_pv;
> > > char procname[MPI_MAX_PROCESSOR_NAME];
> > > double inicio, termino, tempo_parcial, soma_tempo_total, valor;
> > > long long offset;
> > > MPI_Datatype linhaMatriz;
> > > MPI_File arquivo;
> > > MPI_Status status;
> > > MPI_Init(&argc, &argv);
> > > MPI_Comm_rank(MPI_COMM_WORLD, &processo);
> > > MPI_Comm_size(MPI_COMM_WORLD, &num_procs);
> > > MPI_Get_processor_name(procname,&nome_tamanho);
> > > while ((opcao = getopt(argc, argv, "A:D:P:h")) != EOF)
> > > switch(opcao)
> > > case 'A':
> > > arquivo_pv =optarg;
> > > sprintf(arquivo_nome,"%s",arquivo_pv);
> > > break;
> > > case 'D':
> > > sscanf (optarg, "%d", &dimensao);
> > > break;
> > > case 'P':
> > > sprintf(arquivo_nome,"pvfs2:/mnt/pvfs2/%s",arquivo_pv);
> > > MPI_Type_contiguous(dimensao,MPI_DOUBLE,&linhaMatriz);
> > > MPI_Type_commit(&linhaMatriz);
> > > MPI_File_open(MPI_COMM_WORLD, arquivo_nome, MPI_MODE_CREATE |
> > > MPI_MODE_WRONLY, MPI_INFO_NULL, &arquivo);
> > > for(interacao=0; interacao<(dimensao/num_procs);interacao++)
> > > double matrizlocal[dimensao];
> > > valor=processo*(dimensao/num_procs)*dimensao+interacao*dimensao;
> > > offset=valor*sizeof(double);
> > > for(coluna=0; coluna<dimensao; coluna++)
> > > matrizlocal[coluna]=valor+coluna;
> > > MPI_File_set_view(arquivo, offset, MPI_DOUBLE, linhaMatriz,
> > > inicio=MPI_Wtime();
> > > MPI_File_write(arquivo, matrizlocal, 1, linhaMatriz, &status);
> > > termino=MPI_Wtime();
> > > tempo_parcial=termino-inicio;
> > > contador_bytes_parcial+=sizeof(matrizlocal);
> > > soma_tempo_total+=tempo_parcial;
> > > MPI_File_close(&arquivo);
> > > MPI_Allreduce(&soma_tempo_total, &tempo, dimensao, MPI_DOUBLE,
> > > MPI_Finalize();
> > > Do you know what could be happening?
> > > Thanks
> > > Luiz Mendes
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070123/a5e3f8db/attachment.htm>
