[MPICH] ROMIO practice doubts
Luiz Mendes
luizmendesw at gmail.com
Mon Jan 22 08:03:42 CST 2007
Hi all,
Thanks Rob,
I have been reading MPI 2 book, and other materials, and i still be in doubt
with some concepts.
There are some doubt topics that i havent learn yet.
These hints, they are effective only in non-contiguos situations, is it
right?
romio_pvfs_listio_write and read for example, they would be effective in non
contiguous situations?
ROMIO excuses the necessity of build list_io_read function, when we use
these above hints?
And talking about Non-contiguous access, i understood it as a heterogeneous
thing. For example, in a data, we have the first 3 blocks of one type, and
the next block is a different thing with 2 blocks for example. Is it right?
Contiguity refers to belong to a same element?
When i define an MPI_Vector for example, i set non null strides. These blank
spaces, they could be used for other elements?
I am trying to make a simple benchmark to measure bandwith, but i didnt get
it works yet.
Non contiguouos datatypes are only these ones that have strides? if i make a
datatype that consists of a "entire line row" in each block, it could be
considered a non contiguos thing? The hints would do any influency over it?
In MPICH2, i create a mpd.hosts file, but i am not getting it works,
mpdtrace doesnt tell anything about the slave node. What should i do?
Thanks in advance, luiz.
2007/1/22, Rob Ross <rross at mcs.anl.gov>:
> Hi Luiz,
> That's exactly where the hints go. You can also use the
> MPI_File_set_info() call if you like, and you can pass hints it at
> MPI_File_set_view() time as well.
> Regards,
> Rob
> Luiz Mendes wrote:
> > Hi all,
> > I have read MPI 2 book, ROMIO guide and some articles about
> > optimizations for MPI IO. But i didnt see yet or i didnt understand
> > where hints would be placed on MPI_File_open code.
> > Should i use ROMIO hints replaceing MPI_INFO_NULL constant in
> > MPI_File_open function?
> > Thanks in advance
> > Luiz Mendes
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070122/aa21d0f0/attachment.htm>
