[MPICH] MPI 2 - install, mpdtrace problem
Ralph Butler
rbutler at mtsu.edu
Thu Jan 18 14:28:33 CST 2007
Running mpd as root is a pretty special case that the manual
recommends against using
until you have it functioning properly as a regular user. Once you
have that going, then
installing as root for multiple users can be done separately as per
the manual.
On ThuJan 18, at Thu Jan 18 11:16AM, Luiz Mendes wrote:
> Hi all,
> After use mpich1, i decided to install mpich2. During configure i
> use options to enable romio and file system with ufs, nfs and pvfs2.
> Now when i went to test mpdtrace like manual said, it show the
> following message:
> mpdtrace (send_dict_msg 632):send_dict_msg: sock= errmsg=:(32,
> 'Broken pipe'):
> mpdtb:
> /usr/local/MPI2/bin/mpdlib.py, 632, send_dict_msg
> /usr/local/MPI2/bin/mpdtrace, 51, mpdtrace
> /usr/local/MPI2/bin/mpdtrace, 83, ?
> mpdtrace: unexpected msg from mpd=:{'error_msg': 'invalid
> secretword to root mpd'}:
> I write into /etc/mpd.conf secret word and i am using root user.
> What could be? i am reading at Apendix A from Installing Manual,
> but i didnt get anything until now.
> Thanks in advance,
> Luiz Mendes
