[MPICH] Warnings during compilation.
Oliver Fortmeier fortmeier at sc.rwth-aachen.de
Wed Jan 17 02:41:17 CST 2007
Hello,
of course that trick would supress the warnings in your code, if the code is behind the pragma, so I
include the mpich header in one file with no other code, that is included by all other files, that
uses MPI calls.
e.g.:
File: mympi.h
----------Code----------------------
#pragma GCC system_header
#include <mpi.h>
----------End of Code---------------
File: main_prog.cpp
#include "mympi.h"
#include <iostream>
using namespace std;
int main(int argc, char* argv[])
     MPI::Init(argc, argv);
     int a=0;
     MPI::Finalize();
     return 0;
In this example the compiler warns me about the unused variable a. I think this can solve your
problem, if you use the gnu compiler.
Best,
Oliver
Nico Kruithof wrote:
> Yes, that would do the trick, but could also supress warnings in my
> code. I'd rather have that the warnings did not appear in the first
> place.
> Bests,
> Nico
> On Tue, 2007-01-16 at 13:40 +0100, Oliver Fortmeier wrote:
>> Hello,
>> I am using the c++ frontend from mpich2 1.0.2 too. I surpress the warnings given by the  gcc
>> compiler (4.1.1) by including mpi.h like this:
>> #include <mpi.h>
>> If there is another way to do it (compiler independent), I would be glad to hear about it.
>> I hope I could help you,
>> Oliver
>>> Hello,
>>> Is there anything I can do to avoid warnings like:
>>> /opt/mpich/include/mpi2c++/pcomm.h:59: warning: 'class PMPI::Comm' has
>>> virtual functions but non-virtual destructor
>>> which probably means that Comm has a default destructor instead of a
>>> virtual destructor.
>>> Thanks in advance,
>>> Nico
  Institute for Scientific Computing    phone: +49 241 80 24918
  RWTH Aachen University                fax:   +49 241 80 6 24918
