[MPICH] MPICH2 (mpd.conf) problem
Rajeev Thakur thakur at mcs.anl.gov
Thu Feb 22 14:08:16 CST 2007
I guess you are running MPD as root. You may want to see the section on
Running MPD as Root in the installation guide.
Rajeev
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Natarajan, Senthil
Sent: Wednesday, February 21, 2007 4:33 PM
Subject: [MPICH] MPICH2 (mpd.conf) problem
I am using MPICH2 with condor, when I submit the MPI job, it will run as a
user "nobody" on the other machines.
And I am getting this error "unable to find mpd.conf file".
Is their any system variable (like the one to set the port range) is
available so that I can assign the path to "mpd.conf" file.
I have the mpd.conf file under /etc/ (/etc/mpd.conf) can I make use of this
file for the user "nobody".
Please let me know how to fix this.
Senthil
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070222/82675a70/attachment.htm>
