[MPICH] bug in evaluating MPIEXEC_MACHINES_PATH
William Gropp gropp at mcs.anl.gov
Fri Feb 16 09:58:53 CST 2007
No, its just not used very much, and isn't used in our nightly
tests.  It has some limitations because of the limitations of remote
shells (and because it doesn't use a "helper" application at the
destination node).  Most our our testing is done with mpd and
gforker; mpd provides more functions and is more thoroughly tested.
Bill
On Feb 15, 2007, at 9:19 AM, Martin Kleinschmidt wrote:
> On Do, 15 Feb 2007, William Gropp wrote:
>> Thanks for finding this.  remshell is an experimental process manager
>> and hasn't been extensively tested.
> should this discourage me from using it? Is it unstable? Slow?
>> This will be fixed for the next  release, and I can send you a patch
>> (with your next bug as well).
> Thank you, Bill. I already solved the (more important) wdir problem. I
> can easily live with this character deletion issue until the next
> regular
> release.
>    ...martin
