[MPICH] bug in evaluating MPIEXEC_MACHINES_PATH
William Gropp gropp at mcs.anl.gov
Thu Feb 15 07:35:05 CST 2007
Thanks for finding this.  remshell is an experimental process manager
and hasn't been extensively tested.  This will be fixed for the next
release, and I can send you a patch (with your next bug as well).
Bill
On Feb 15, 2007, at 3:19 AM, Martin Kleinschmidt wrote:
> when evaluating MPIEXEC_MACHINES_PATH, remshell throws away the last
> character of MPIEXEC_MACHINES_PATH, regardless if it is a slash or
> not:
> $ setenv MPIEXEC_MACHINES_PATH `pwd`
> $ echo $MPIEXEC_MACHINES_PATH
> /data2/mk/518977.fats.theochem.uni-duesseldorf.de
> $ mpiexec -n 4 program
> Could not open machines file
> /data2/mk/518977.fats.theochem.uni-duesseldorf.d/machines
> Could not find machines for default architecture
> Unable to assign hosts to processes
> note the missing "e" at the end of the directory name!
> adding a slash for removal helps:
> $ setenv MPIEXEC_MACHINES_PATH /data2/mk/518977.fats.theochem.uni-
> duesseldorf.de/
> /data2/mk/518977.fats.theochem.uni-duesseldorf.de/
> mpiexec -n 4 ~/prog/mrci/mrci.my_version/mrci
> (runs)
> The last character should only be thrown away if it is irrelevant.
>    ...martin
> Wir muessen jetzt endlich den Arsch hoch kriegen und Eier zeigen.
> (Martin Pieckenhagen)
