[MPICH] configuting mpich2-1.0.5p2 problems to be used with Totalview 8.0.2-0 later
Manal Helal
manalorama at gmail.com
Mon Feb 12 17:32:58 CST 2007
Hi Rajeev
Thank you very much, sorry I just thought that the file is corrupted on
your machine only, but when Anthony said the same, I did the retyping by
hand, and it is working,
thank you very much for your help,
Best Regards,
On 13/02/07, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> Your problem is caused by some strange characters that your cut-and-paste
> method is adding to the command line. Just type the configure command
> entirely by hand.
> Rajeev
> *From:* owner-mpich-discuss at mcs.anl.gov [mailto:
> owner-mpich-discuss at mcs.anl.gov] *On Behalf Of *Manal Helal
> *Sent:* Monday, February 12, 2007 1:22 AM
> *To:* Anthony Chan
> *Cc:* mpich-discuss at mcs.anl.gov
> *Subject:* Re: [MPICH] configuting mpich2-1.0.5p2 problems to be used with
> Hi
> Thank you very much for your reply.
> Please find the requested files attached, and the Linux flavour I am
> working on is FC5
> 2.6.18-1.2239.fc5 #1 Fri Nov 10 13:04:06 EST 2006 i686 i686 i386
> GNU/Linux
> and the gcc version is:
> gcc (GCC) 4.1.1 20060525 (Red Hat 4.1.1-1)
> I appreciate your help, thanks,
> On 12/02/07, Anthony Chan < chan at mcs.anl.gov> wrote:
> > On Mon, 12 Feb 2007, Manal Helal wrote:
> > > and was advised by Rajeev, to igoner the defaults and use only:
> > > $./configure -prefix=/pathxx/mpich2-install --enable-debuginfo
> > > --enable-g=dbg,mem,log --enable-sharedlibs=gcc | & tee configure.log
> > > both gave me errors: here is what I get early on the configure.logfile:
> > > configure: WARNING: you should use --build, --host, --target
> > > configure: WARNING: invalid host type: --enable-debuginfo
> > > and then at the end
> > > checking for virtual path format... VPATH
> > > checking build system type... Invalid configuration
> > > `--enable-debuginfo': machine `--enable' not recognized
> > > configure: error:
> > > */home/mhelal/MyDownloads/mpich2-1.0.5p2/src/mpe2/src/misc/*../.
> > > ./config.sub
> > > --enable-debuginfo failed
> > > configure: error: /bin/sh
> > > '/home/mhelal/MyDownloads/mpich2-1.0.5p2/src/mpe2/src/misc/configure'
> > > failed for src/misc
> > > configure: error: Configure of src/mpe2 failed!
> > > Thank you very much for your time,
> > It seems the configure thought that you were doing a cross-compilation.
> > I tried your configure command on a linux box, the configure went
> > through
> > without any error. Can you send us your configure.log and the
> > <mpich2-build-dir>/src/mpe2/src/misc/config.log ?
> > A.Chan
> Kind Regards,
> Manal Helal
Kind Regards,
Manal Helal
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070213/1ac6bcd1/attachment.htm>
