[MPICH] configuting mpich2-1.0.5p2 problems to be used with Totalview 8.0.2-0 later
Manal Helal
manalorama at gmail.com
Mon Feb 12 01:22:27 CST 2007
Hi
Thank you very much for your reply.
Please find the requested files attached, and the Linux flavour I am working
on is FC5
2.6.18-1.2239.fc5 #1 Fri Nov 10 13:04:06 EST 2006 i686 i686 i386 GNU/Linux
and the gcc version is:
gcc (GCC) 4.1.1 20060525 (Red Hat 4.1.1-1)
I appreciate your help, thanks,
On 12/02/07, Anthony Chan <chan at mcs.anl.gov> wrote:
> On Mon, 12 Feb 2007, Manal Helal wrote:
> > and was advised by Rajeev, to igoner the defaults and use only:
> > $./configure -prefix=/pathxx/mpich2-install --enable-debuginfo
> > --enable-g=dbg,mem,log --enable-sharedlibs=gcc | & tee configure.log
> > both gave me errors: here is what I get early on the configure.log file:
> > configure: WARNING: you should use --build, --host, --target
> > configure: WARNING: invalid host type: --enable-debuginfo
> > and then at the end
> > checking for virtual path format... VPATH
> > checking build system type... Invalid configuration
> > `--enable-debuginfo': machine `--enable' not recognized
> > configure: error:
> > */home/mhelal/MyDownloads/mpich2-1.0.5p2/src/mpe2/src/misc/*../.
> > ./config.sub
> > --enable-debuginfo failed
> > configure: error: /bin/sh
> > '/home/mhelal/MyDownloads/mpich2-1.0.5p2/src/mpe2/src/misc/configure'
> > failed for src/misc
> > configure: error: Configure of src/mpe2 failed!
> > Thank you very much for your time,
> It seems the configure thought that you were doing a cross-compilation.
> I tried your configure command on a linux box, the configure went through
> without any error. Can you send us your configure.log and the
> <mpich2-build-dir>/src/mpe2/src/misc/config.log ?
> A.Chan
Kind Regards,
Manal Helal
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070212/b5ed255f/attachment.htm>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070212/b5ed255f/attachment.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070212/b5ed255f/attachment-0001.bin>
