[MPICH] mpdboot errors
Luiz Mendes
luizmendesw at gmail.com
Fri Feb 2 15:36:33 CST 2007
HI all,
Well, i have posted this stuff some days ago, in that ocasion i hadnt tried
somethings to stress all possibilities.
After several attempts i come back here again to ask for this following
error;
When i use mpdboot, only two machines are correctly recognized. For example:
I have 6 PCS. with names from "fisio1" to "fisio6".
With Mpich1, all these PCS have comunicate with each other without problems.
When i try with MPICH2 i have problems.
for example:
I defined a file with hosts
later i input the following command:
mpiboot -n 3 -f hostfile
With error:
sometimes
mpdboot_fisio1 (handle_mpd_output 374): failed to ping mpd on fisio3; recvd
output={}
and another time
mpdboot_fisio1 (handle_mpd_output 374): failed to ping mpd on fisio5; recvd
output={}
As you see, i think that this is not a problem of comunication between PCS,
because with 2 PCS, MPDboot works correctly.
And the same PC that reports communication errors on some ocasions in
another situations works correctly.
What it could be?
Thanks in advance
Luiz Mendes
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070202/b782c86f/attachment.htm>
