[MPICH] can't set up mpd ring between two nodes
Rajeev Thakur
thakur at mcs.anl.gov
Wed Dec 26 23:08:04 CST 2007
The networking environment on the machines may not be set up correctly. To
debug the problem, you can use the mpdcheck utility as described in the
installation guide.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of jetspeed
> Sent: Wednesday, December 26, 2007 7:49 AM
> To: mpi
> Subject: [MPICH] can't set up mpd ring between two nodes
> Hi all:
> I installed mvapich2 , which is with the OFED 1.2.5.
> 1. when I use mpdboot on a machine, I got :
> mpdboot_inode02 (handle_mpd_output 359): failed to
> ping mpd on inode02; recvd output={}
> 2. when I try to use mpd to set up mpd ring, as the
> user guide of mpich2:
> mpd & on node02
> mpd -h node02 -p port on node01
> I got:
> on node01: (the latter mpd)
> inode01_33435 (connect_lhs 621): invalid challenge from
> inode02 32969: {}
> inode01_33435 (enter_ring 566): lhs connect failed
> inode01_33435 (run 233): failed to enter ring
> on node02: (the first mpd )
> inode02_32969: mpd_uncaught_except_tb handling:
> exceptions.TypeError: sequence item 0: expected string, int found
> /usr/mpi/gcc/mvapich2-0.9.8-15/bin/mpdlib.py 733
> handle_ring_listener_connection
> newsock.correctChallengeResponse = \
> /usr/mpi/gcc/mvapich2-0.9.8-15/bin/mpdlib.py 488
> handle_active_streams handler(stream,*args)
> /usr/mpi/gcc/mvapich2-0.9.8-15/bin/mpd 266 runmainloop
> rv = self.streamHandler.handle_active_streams(timeout=8.0)
> /usr/mpi/gcc/mvapich2-0.9.8-15/bin/mpd 240 run
> self.runmainloop()
> /usr/mpi/gcc/mvapich2-0.9.8-15/bin/mpd 1344 ?
> mpd.run()
> Has anyone encountered this problem?
> Thanks in advance.
