[MPICH] any way to ask nemesis to turn-off and turn of active polling ?
chong tan
chong_guan_tan at yahoo.com
Mon Dec 17 13:00:30 CST 2007
I don;t have root access to the box. I will see if I can ask sys-admin to do it. I am running
Linux snowwhite 2.6.18-8.el5 #1 SMP
DO you know if the broken yield got into this version ?
FYI : the 'yield' people said it is not 'broken', it is in fact the 'right yield'.
tan
----- Original Message ----
To: chong tan <chong_guan_tan at yahoo.com>
Cc: mpich-discuss at mcs.anl.gov
Sent: Monday, December 17, 2007 10:50:12 AM
Subject: Re: [MPICH] any way to ask nemesis to turn-off and turn of active polling ?
Try setting the processor affinity for the "average" processes (map each
one to its own processor). If you have a kernel with the "broken"
sched_yield implementations, that may not help.
If you have a "broken" sched_yield implementation, you can try doing
this as root:
sysctl kernel.sched_compat_yield=1
or
echo "1">/proc/sys/kernel/sched_compat_yield
-d
On 12/17/2007 11:35 AM, chong tan wrote:
> Yes, in a very subtle way which has major impact on performance. I will
> try to decribe it a litle here:
> system has 32G, total image 35G. Load is a litle offbalance
> mathematically, 4X dual core, running 5 processes.
> 4 processes are the same size, each runs on a CPU. the last process is
> very small, about10% of others, run
> on a core of one of the CPU. SO 1 CPU runs 2 procs: average (P1)one and
> light one (P2).
> All proc do first MPI comm in a fixed algorithmic point. The 'useful'
> image is about 29G at that point, and should
> fit into the physical memory. P2 get there in a heart beat, then
> others., followed by P1 which took another 60+ minutes
> to get there. If I combine P1 and P2 into 1 process, then I don;t no
> see this extra delay.
> tan
> From: Darius Buntinas <buntinas at mcs.anl.gov>
> Sent: Monday, December 17, 2007 8:02:17 AM
> active polling ?
> No, there's no way to do that. Even MPI_Barrier will do active polling.
> Are you having issues where an MPI process that is waiting in a blocking
> call is taking CPU time away from other processes?
> -d
> On 12/14/2007 04:53 PM, chong tan wrote:
> > My issue is like this :
> > among all the processess, some will get to the point of first MPI
> > communication points faster than
> > than other. Is there a way that I tell nemesis to start without doing
> > active polling, and then turn
> > on active polling with some function ?
> > Or should I just use MPI_Barrier() on that ?
> > thanks
> > tan
> > Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try
> > it now.
> <http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> it now.
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071217/7c6bd1ba/attachment.htm>
