[MPICH] Problem with MPI_Gather
    Pavan Balaji
    balaji at mcs.anl.gov
    Mon Dec 17 08:09:26 CST 2007
Sending the correction patch to mpich-discuss as well.
 -- Pavan
Jonathan Patterson wrote:
>> Hello, Jonathan!
>> I have tested your example with mpich2 1.0.6 the previous stable release of
> mpich2 and
>> found the example work correctly. I have compiled your program with
> mpich2-1.0.6p1 with
>> gather.c taken from src/mpi/coll of mpich2-1.0.6 distribution and found the
> example to work
>> as well. The problem with 1.0.6p1 seems to show only with messages of size
> greater than the
>> value of MPIR_GATHER_VSMALL_MSG set in mpiimpl.h . Currently this constant is
> set to
>> 1024 bytes which explains why reducing DATASIZE to less than 256 removes the
> bug on
>> 32 bit machines. I hope someone from the developers will come up with a fix
> soon, since
>> the algorithm seems to have been slightly modified in 1.0.6p1.
> 	Thanks a lot for your very helpful reply. I'll submit it as a bug.
Pavan Balaji
http://www.mcs.anl.gov/~balaji
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071217/87764fa7/attachment.bin>
