[MPICH] Problem when enabling ADIOI_MPE_LOGGING
    Christina Patrick
    christina.subscribes at gmail.com
    Sun Dec  2 14:44:02 CST 2007
Thank you very much Anthony. I figured out a lot of things with your
help. I am now able to time the events and get a breakup of the
collective routine times.
Thanks and Regards,
Christina.
On Dec 1, 2007 11:42 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> On Sat, 1 Dec 2007, Christina Patrick wrote:
> > Hi Anthony,
> > Thank you very much for the detailed explanation above.
> > When I logged the IDs  ADIOI_MPE_write_a and  ADIOI_MPE_write_b, it
> > gave me the following:
> > ADIOI_MPE_write_a     = 604 ADIOI_MPE_write_b     = 605
> > The file "src/mpi/romio/adio/common/ad_init.c" logs the write events as follows:
> > MPE_Describe_state( ADIOI_MPE_write_a, ADIOI_MPE_write_b, "write", "blue" );
> > Inside jumpshot, I can see a "write" event inside a
> > "MPI_File_write_at_all" (light blue block inside a dark blue block).
> > My questions are:
> > 1. What are events 1, 2, 3 & 4 (I logged all the eventIDs in ad_init.c
> > and they range from 600 to 617. I don't have any eventIDs numbered 1,
> > 2, 3 & 4)?
> The eventIDs, ADIOI_MPE_write_a and ADIOI_MPE_write_b, are defined/fetched
> from MPE logging libraries.  The exact IDs depend on what are available
> in the MPE library.  You shouldn't worry about the exact numbers.
> EventIDs 1,2,3,4 have already assigned by MPE for MPI states.  See
> mpich2/src/mpe2/README's custom logging section and/or
> <mpich2-install-dir>/src/cpilog.c to understand how MPE routines
> are used.
> > 2. Can I explicity get the timing between events 604 & 605?
> You can right click on the "write" state, the light blue rectangle,
> in jumpshot to get a drawable popup info box which will show
> the duration.  For more info on how to use jumpshot, click the
> help button in jumpshot or see
> http://www-unix.mcs.anl.gov/perfvis/software/viewers/jumpshot-4/usersguide.html
> This is how drawable popup info box looks like:
> http://www-unix.mcs.anl.gov/perfvis/software/viewers/jumpshot-4/node20.html
> A.Chan
> > Thanks and Warm Regards,
> > Christina.
> > On Dec 1, 2007 1:11 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> >> Just to be clear, ADIOI_MPE_LOGGING only enables client side logging.
> >> Also I would think that a typical MPICH2 build with ADIOI_MPE_LOGGING
> >> enabled will cause compilation error (so not sure what you did).
> >> In order to get ADIOI_MPE_LOGGING to work correctly, you need to build
> >> mpich2 *TWICE* with second build dependent on the first one.  The main
> >> reason is that MPICH2 builds MPE after ROMIO/ADIO.  In order words,
> >> ADIOI_MPE_LOGGING can't be enabled without a valid set of MPE logging
> >> header files. So here are the steps that I would do,
> >> 1, untar a new copy of mpich2, say mpich2-1.0.6p1, into directory
> >>    <mpich2>
> >> 2, build a standard version of mpich2 with all the options that you
> >>    normally need using VPATH build.  You don't want to do inpath build
> >>    here because we need clean mpich2 source tree for the 2nd build, i.e.
> >>    mkdir <build_std>
> >>    cd <build_std>
> >>    <mpich2>/configure CC=... CXX=... F77=... F90=... \
> >>                       --prefix=<install_std>
> >>    make
> >>    make install
> >>    Notice we have the 1st installation of MPICH2 in <install_std>.
> >> 3, build another version of mpich2 with an extra CFLAGS that enables
> >>    ADIOI_MPE_LOGGING and points to a valid set of MPE logging include
> >>    files, i.e. -I<install_std>/include.
> >>    mkdir <build_adiolog>
> >>    cd <build_adiolog>
> >>           --prefix=<install_adiolog>                   \
> >>           --with-file-system=pvfs2+pvfs+ufs+nfs        \
> >>           --with-pvfs2=<pvfs-install-dir>              \
> >>           CFLAGS="-DADIOI_MPE_LOGGING -I<install_std>/include"
> >>    make
> >>    make install
> >>    The 2nd installation of MPICH2 will be in <install_adiolog>.
> >> 4, now you can compile your MPIO+PVFS application with
> >>    <install_adiolog>/bin/mpicc -mpe=mpilog -c foo.c
> >>    and link as
> >>    <install_adiolog>/bin/mpicc -mpe=mpilog -o <exe> *.o
> >>    mpiXX wrappers from <install_adiolog> must be used with -mpe=mpilog
> >>    for linking, because libmpich.a in <install_adiolog> has references
> >>    to MPE symbols.
> >> 5, Now run the <exe> as usual.  This will generate clog2 file with
> >>    {read,write,seek,...} nested inside MPIO states.  Then invoke
> >>    jumpshot on the clog2, and follows the GUI.
> >> ADIOI_MPE_LOGGING isn't meant for general users, so no big effort
> >> has been spent to make this easy. Let me know if this works for you
> >> though.
> >> A.Chan
> >> On Fri, 30 Nov 2007, Christina Patrick wrote:
> >>> Hi Everybody,
> >>> I want to monitor the time it takes to complete collective I/O in my
> >>> application. However, I also want the breakup of the times the
> >>> collective call spends in calling the PVFS functions as well as the
> >>> communication. I saw some ready made logging present in the files
> >>> ad_pvfs2_write.c. The calls PVFS_sys_write were logged by MPE_Log
> >>> event() as below (one excerpt of the code):
> >>> #ifdef ADIOI_MPE_LOGGING
> >>>                    MPE_Log_event( ADIOI_MPE_write_a, 0, NULL );
> >>> #endif
> >>>                    err_flag = PVFS_sys_write(pvfs_fs->object_ref, file_req,
> >>>                                              file_offsets, PVFS_BOTTOM,
> >>>                                              mem_req,
> >>>                                              &(pvfs_fs->credentials),
> >>>                                              &resp_io);
> >>>                    MPE_Log_event( ADIOI_MPE_write_b, 0, NULL );
> >>> #endif
> >>> I modified the makefiles to add the debug flag ADIOI_MPE_LOGGING and
> >>> enabled the logging. However, when I run my application and generate
> >>> the clog and slog files, I cannot see these events using jumpshot. I
> >>> logged the event ID's when they are created in ad_init.c and they are
> >>> as below from a sample run:
> >>> What am I missing? Is there something that I need to do additionally?
> >>> How exactly should I profile my application and which tool should I
> >>> use to get the breakup of these times.
> >>> I have never profiled MPI before. I would really appreciate any help
> >>> and suggestions that you could offer.
> >>> Thanks and Regards,
> >>> Christina.
