[MPICH] Graphs with Jumpshot
Anthony Chan
chan at mcs.anl.gov
Wed Aug 8 09:07:06 CDT 2007
It sounds like you are using the rlog not clog2 (from MPE). rlog is
designed to profile the MPICH2 internal, i.e. for MPICH2 developers.
It contains a lot more info than a typical MPI users needed. If you
are not interested in improving MPICH2 implementation, you should consider
using MPE logging, i.e. , using "mpicc -mpe=mpilog" to link your
program and generate a clog2 file which can be viewed by Jumpshot.
See mpich2-xxx/src/mpe2/README for more details or
http://www.mcs.anl.gov/perfvis
A.Chan
On Wed, 8 Aug 2007, Calin Iaru wrote:
> It's OK, I think I can filter the output using printirlog utility. This
> would allow for queries on different functions. Can someone explain why
> does IARROW event has a remote "-2". I would expect that the remote
> field in the RLOG_IARROW structure to be the pair rank.
> Best regards,
> Calin
> Calin Iaru wrote:
> > Hi all,
> > I would like to see a graph of the time spent doing some MPI
> > operation. The X axis would be the number of samples and the Y axis
> > would be the time. Is there a way to do this with jumpshot? Otherwise,
> > is there a way to extract this information from slog2 files?
> > Best regards,
> > Calin
