[MPICH] MPICH 105, build failure with ssm
William Gropp
gropp at mcs.anl.gov
Mon Apr 30 19:24:20 CDT 2007
Thanks for the report. I believe that this is our error; some of the
code was not properly encapsulated, so when we turned of some
experimental code, we didn't remove it from the build. In other
words, I don't think this code is used any more, but its presence
broke your build. We'll fix that for the next release.
Bill
On Apr 24, 2007, at 2:26 PM, chong tan wrote:
> build script :
> ./configure -prefix=/u/cgtan/my_release_dir__niagara --with-
> device=ch3:ssm --enable-fast |& tee configure.log
> error :
> shmproc.c: In function `MPIDI_SHM_AttachProc':
> shmproc.c:59: error: `PTRACE_ATTACH' undeclared (first use in this
> function)
> shmproc.c:59: error: (Each undeclared identifier is reported only once
> shmproc.c:59: error: for each function it appears in.)
> shmproc.c: In function `MPIDI_SHM_DetachProc':
> shmproc.c:80: error: `PTRACE_DETACH' undeclared (first use in this
> function)
> shmproc.c: In function `MPIDI_SHM_ReadProcessMemory':
> shmproc.c:115: error: `PTRACE_PEEKDATA' undeclared (first use in
> this function)
> shmproc.c:115: warning: passing arg 3 of `ptrace' makes integer
> from pointer without a cast
> make[5]: *** [shmproc.o] Error 1
> any suggestion ?
> thanks
> Ahhh...imagining that irresistible "new car" smell?
> Check out new cars at Yahoo! Autos.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070430/2332e932/attachment.htm>
