[MPICH] SSM channel on Solaris 64bit
Rajeev Thakur
thakur at mcs.anl.gov
Thu Apr 26 08:46:05 CDT 2007
I believe if you use gcc on Solaris it should work. With the native Solaris
compilers it doesn't.
Rajeev
> -----Original Message-----
> From: James S Perrin [mailto:james.s.perrin at manchester.ac.uk]
> Sent: Thursday, April 26, 2007 8:11 AM
> To: Rajeev Thakur
> Subject: Re: [MPICH] SSM channel on Solaris 64bit
> Thanks, I just wanted to check whether this was a compiler
> choice issue.
> Regards
> James
> Rajeev Thakur wrote:
> > ssm used to work on Solaris earlier, but not currently.
> That is why the line
> > "Please volunteer to fix this code" got added to the error
> message :-). I
> > will update the release notes.
> > Rajeev
> >> From: owner-mpich-discuss at mcs.anl.gov
> >> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> James S Perrin
> >> Sent: Wednesday, April 25, 2007 5:10 AM
> >> To: mpich
> >> Subject: [MPICH] SSM channel on Solaris 64bit
> >> Hi,
> >> I trying to configure MPICH2 1.0.5p4 on Solaris 9 with
> >> the Sun Studio
> >> 11 compilers. I wish to use the ch3:ssm channel. From the
> >> release notes:
> >> "The ssm channel uses special interprocess locks (often
> >> assembly) that
> >> may not work with some compilers or machine architectures.
> >> ... It also
> >> works in Windows and Solaris environments."
> >> I'm presuming this means if using gcc (the default) under
> >> Solaris as I
> >> got the following error:
> >> configure: error: Use of inline process locks is not
> >> supported. Please
> >> configure: error: Configure of src/mpid/common/locks failed!
> >> I had set the following env and run configure as:
> >> CC=cc
> >> CXX=CC
> >> CFLAGS=-xarch=v9 -xcode=pic32 -xs -O -xmemalign=8s
> >> CXXFLAGS=-xarch=v9 -xcode=pic32 -xs -O -xmemalign=8s
> >> ./configure --with-mpe --with-pm=mpd --with-device=ch3:ssm
> >> --with-thread-package=pthreads --disable-f77 --disable-f90
> >> I just needs my suspicions confirmed.
> >> Regards
> >> James
> >> James S. Perrin, | email:
> >> james.perrin at manchester.ac.uk
> >> Manchester Visualization Centre, | web: www.mc.manchester.ac.uk
> >> Kilburn Building, The University, | tel: +44 161 275 6945
> >> Manchester, England. M13 9PL. | fax: +44 161 275 0637
> >> "The test of intellect is the refusal to belabour the obvious"
> >> - Alfred Bester
> - Alfred Bester
