[MPICH] MPI-IO, reading in c++ from fortran generated file
Stephen Wornom
Stephen.Wornom at sophia.inria.fr
Tue Apr 24 02:32:13 CDT 2007
Rob Ross wrote:
> Hi Russell,
> Sure you can read them, it's just that MPI-IO doesn't have any
> mechanism for *interpreting* whatever "stuff" fortran is putting in
> there.
google for David Cronk, he has applied MPI-IO to fortran production
codes. The attached ppt if from his web site, perhaps he can participate
in the discussion.
Stephen
> Note that there is no standard for unformatted fortran files, so just
> doing this in MPI-IO would be difficult, especially if one wanted to
> be able to read an unformatted fortran file from another
> system/compiler (which people would invariably try to do). Looks like
> your version of fortran uses the "surround records with byte lengths"
> system, which is where those 4s and 12s come from.
> Regards,
> Rob
> Russell L. Carter wrote:
>> Now that I've looked into it, unformatted fortran files become
>> even more complicated to deal with because of the record header/
>> trailers when implementing collective IO. Just in case I've
>> missed something, is it true there is no way to read unformatted
>> fortran files with MPI-IO?
>> It's obvious once you think about it, but it would have been nice
>> to have that pointed out in the "Using MPI-2" book. (Maybe it is?)
>> Thanks,
>> Russell
Type: application/vnd.ms-powerpoint
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070424/991c320c/attachment.ppt>
