[MPICH] Problem with -machinefile
    Blankenship, David
    David.Blankenship at kla-tencor.com
    Fri Apr 20 16:38:51 CDT 2007
That does seem to fix the problem. Thank you.
David
Sent: Friday, April 20, 2007 12:56 PM
To: Blankenship, David; mpich-discuss at mcs.anl.gov
Subject: RE: [MPICH] Problem with -machinefile
Are you using the latest release, 1.0.5p4? There is a fix in there for a
problem with machinefile. It might help.
Rajeev
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Blankenship, David
	Sent: Friday, April 20, 2007 11:27 AM
	Subject: [MPICH] Problem with -machinefile
	I am having a problem running mpiexec with the -machine file
option. (Red Hat Enterprise 4 - 64 bit)
	When I use the -machinefile option, my application hangs
(deadlocks) while attempting communication. The master is sending, the
workers are receiving, but nothing happens. Any thoughts?
	I start my MPD ring as follows:
	> mpdboot -n 3 -f mpd.hosts
	> cat mpd.hosts
	pad-lnx52:2
	noclue:2
	question:4
	I can then run my application with the -host option or by
letting the MPD ring choose the systems using either of the following
command lines:
	> mpiexec -l -n 1 -host pad-lnx52 lithorun
dev/LithoWare/Samples/FEM1D.xml Output.xml : -n 2 -host noclue lithorun
: -n 2 -host question lithorun
	> mpiexec -l -n 5 lithorun dev/LithoWare/Samples/FEM1D.xml
Output.xml
	But when I try to use the -machine file option, my application
hangs. The master is sending; all of the workers are receiving, but no
communication appears to actually be happening.
	> mpiexec -machinefile mpd.hosts -l -n 5 lithorun
	Here is trace of the process when it hangs. You can see that the
workers have been started and are waiting for a work packet in a
MPI::COMM_WORLD.Probe call. The master has divided up the work and is
attempting to send the first packet using a MPI::COMM_WORLD.Send call.
Then, nothing else happens. This only occurs when I am trying to use the
-machinefile option.
	3: Worker on noclue
	3: Waiting for work...
	2: Worker on noclue
	2: Waiting for work...
	1: Worker on pad-lnx52.kla-tencor.com
	1: Waiting for work...
	0: Master on pad-lnx52.kla-tencor.com
	0: Loading dev/LithoWare/Samples/FEM1D.xml
	0: Found Factorial(FEM1D)
	4: Worker on question.kla-tencor.com
	4: Waiting for work...
	0: Loading Sample.plt
	0: Distributing Factorial(FEM1D) with 45 experiments over 4
processes with 3 work packets
	0: Sending work(1625)
	For a point of reference here is a trace of the process when it
works:
Output.xml
	1: Worker on noclue
	2: Worker on noclue
	3: Worker on question.kla-tencor.com
	0: Sent work(1625)
	0: Sending work(1619)
	4: Received work(1625)
	4: Found Factorial(FEM1D)
	4: Loading Sample.plt
	0: Sent work(1619)
	0: Sending work(1622)
	4: Running Factorial(FEM1D) with 15 experiments
	3: Received work(1619)
	3: Found Factorial(FEM1D)
	3: Loading Sample.plt
	3: Running Factorial(FEM1D) with 15 experiments
	0: Sent work(1622)
	0: Waiting for results...
	2: Received work(1622)
	2: Found Factorial(FEM1D)
	2: Loading Sample.plt
	2: Running Factorial(FEM1D) with 15 experiments
	0: Received results(1672)
	4: Factorial(FEM1D) complete (0.04175)
	4: Sending results(1672)
	3: Factorial(FEM1D) complete (0.0420239)
	0: Received results(1652)
	3: Sending results(1652)
	2: Factorial(FEM1D) complete (0.0852771)
	0: Received results(1400)
	0: Factorial(FEM1D) complete (0.136751)
	2: Sending results(1400)
	1: Received work(0)
	4: Received work(0)
	3: Received work(0)
	2: Received work(0)
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070420/6d9b132c/attachment.htm>
