[MPICH] mpich2-1.0.5p4 build failure with PGI 6.2
David Gunter
dog at lanl.gov
Fri Apr 20 16:10:31 CDT 2007
I've always followed the idea that you need to build each MPI (at
least the Fortran bits) with each Fortran compiler you use. There
are a few reasons for this: 1) F90/F95 module bindings are compiler
specific; 2) Different compilers return different values and sizes
for Fortran boolean types (some use true/false = -1/0, others use
true/false = +1/0 for example).
Granted, this is only an issue if your users are writing actual MPI
codes inside Fortran modules and/or using MPI boolean types in
Fortran, unless I'm missing something else.
-david
David Gunter
HPC-4: HPC Environments: Parallel Tools Team
Los Alamos National Laboratory
On Apr 20, 2007, at 2:52 PM, Garrick Staples wrote:
> On Fri, Apr 20, 2007 at 03:44:03PM -0500, William Gropp alleged:
>> Ah, but you don't need to use the same compiler to built the MPI
>> libraries as the compiler that the user is using, they only need to
>> make the same decisions about basic datatype lengths and they need to
>> have compatible libraries. You should be able to use gcc to build
>> MPICH2 with Nemesis, then use pgcc for the user program, with
>> possibly a little tweeking of the compilation scripts. Its that
>> little tweeking that makes it easier to simply build with the same
>> compiler, but it isn't a requirement.
> I'm playing with these different combinations now. I have to support
> gcc 3.4 (base compiler with centos4), gcc 4.1, intel 9.1, and pgi 6.2
> (and probably now pgi 7.0).
> It would make sense to use gcc 3.4 for everything, except that it
> doesn't have f90; so I'm wondering which f90 compiler I should use.
> With mpich1, I've always just done multiple builds with everything I
> need in multiple directories.
> Garrick Staples, GNU/Linux HPCC SysAdmin
> University of Southern California
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070420/bb939948/attachment.htm>
