[MPICH] Help With I/O
Erich Peterson
erichpeterson at hotmail.com
Wed Apr 18 03:01:55 CDT 2007
Hi all, I'm trying to write this little routine which is part of my graduate project. What I'm trying to do is pass a vector of bools in to the QueryData method. In that method I split the vector up into equal parts among the number of processes, have each process open a datafile which as 20 byte records (no new lines), read that record from the file if the vector they are checking has "true" (basically if vector[0] = true, it means grab the first record of the file), and lastly, it should output that record into a new file. I have been able to determine it is messing up on the for-loop. The error is:
[Student at cluster1 erich_test_area]$ mpiexec -n 3 /mnt/pvfs2/acxiom/erich_test_area/RecordRetrievalterminate called after throwing an instance of 'MPI::Exception'terminate called after throwing an instance of 'MPI::Exception'terminate called after throwing an instance of 'MPI::Exception'rank 0 in job 1 cluster1_33602 caused collective abort of all ranks exit status of rank 0: killed by signal 6 If someone could please tell me or edit the code if they see what is wrong. Thanks! Main.cpp:
#include "RecordRetrieval.h"#include <vector.h>
int main(){ vector<bool> vec;
vec.push_back(true); vec.push_back(false); vec.push_back(true); vec.push_back(false); vec.push_back(true); vec.push_back(false);
RecordRetrieval rec;
rec.QueryData(vec, "test.dat");
return 0;}
RecordRetrieval.cpp:
#include "RecordRetrieval.h"#include "mpi.h"#include "time.h"#include "iostream.h"
void RecordRetrieval::QueryData(vector<bool> unencoded_vector, char * filename){ int num_processes; int num_vector_elements; float num_elements_per_rank; int local_start_position; int local_end_position; char * buf; int my_rank;
MPI::File input_file; MPI::Status input_file_status;
MPI::File output_file; MPI::Status output_file_status; //MPI::Offset filesize;
char output_filename[30]; size_t i; struct tm tim; time_t now; now = time(NULL); tim = *(localtime(&now)); i = strftime(output_filename, 30, "%m_%d_%Y_%H_%M_%S", &tim);
/* Let the system do what it needs to start up MPI */ MPI::Init();
/* Get my process rank */ my_rank = MPI::COMM_WORLD.Get_rank();
/* Find out how many processes are being used */ num_processes = MPI::COMM_WORLD.Get_size();
num_vector_elements = unencoded_vector.size();
num_elements_per_rank = num_vector_elements / num_processes;
local_start_position = my_rank * (int)num_elements_per_rank;
if(my_rank == num_processes - 1) { if(num_elements_per_rank * num_processes == (int)num_elements_per_rank * num_processes) { local_end_position = local_start_position + ((int)num_elements_per_rank - 1); } else { local_end_position = (local_start_position + (int)num_elements_per_rank - 1) + (((int)num_elements_per_rank * num_processes) - ((int)num_elements_per_rank * num_processes)); } } else { local_end_position = local_start_position + ((int)num_elements_per_rank - 1); }
input_file = MPI::File::Open(MPI::COMM_WORLD, filename, MPI::MODE_RDONLY, MPI::INFO_NULL);
output_file = MPI::File::Open(MPI::COMM_WORLD, output_filename, MPI::MODE_CREATE | MPI::MODE_WRONLY, MPI::INFO_NULL);
// filesize = input_file.Get_size();
for(int i = local_start_position; i < local_end_position + 1; i++) { if(unencoded_vector[i]) { input_file.Read_at(i * 20, buf, 20, MPI_CHAR, input_file_status); output_file.Write_shared(buf, 20, MPI_CHAR, output_file_status); } } cout << "Error"; input_file.Close(); output_file.Close(); MPI::Finalize();}
_________________________________________________________________
Discover the new Windows Vista
http://search.msn.com/results.aspx?q=windows+vista&mkt=en-US&form=QBRE
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070418/85aaac78/attachment.htm>
