[MPICH] MPICH2 and PVFS2
    Scott Atchley
    atchley at myri.com
    Fri Apr 13 14:56:22 CDT 2007
Darius,
I have not yet tested ch3:nemesis:mx on Myrinet-2000 hardware. It may
be the performance is sufficient.
Peter, which Myrinet-2000 do you have? Single port D or F cards or
dual port E cards? If you have MX loaded, simply run:
$ /opt/mx/bin/mx_info
If you have GM loaded, run:
$ /opt/gm/bin/gm_board_info
and send the results.
Scott
On Apr 13, 2007, at 3:28 PM, Darius Buntinas wrote:
> MPICH2 does support MX, but performance has not been tuned yet.
> Also, Myricom is actively working on their own MPICH2 port over
> MX.  So depending on how long your MX transition takes, the MX port
> may be completed.
> Darius
> Peter Diamessis wrote:
>> Hi Rob,
>> Actually, one more thing. I did contact our system admin. .
>> He says he'll install MPICH2 but is concerned as to whether
>> it supports MX ? The cluster is currently set-up using GM but
>> they are transitioning to MX and his understanding of your email
>> is that MX is not supported by MPICH2 ? Thus, open-MPI may
>> the cluster's ultimate option ?
>> Any thoughts here ?
>> Sincerely,
>> Peter Diamessis
>> ----- Original Message ----- From: "Robert Latham" <robl at mcs.anl.gov>
>> To: "Peter Diamessis" <pjd38 at cornell.edu>
>> Cc: <mpich-discuss at mcs.anl.gov>
>> Sent: Friday, April 13, 2007 12:21 PM
>> Subject: Re: [MPICH] MPICH2 and PVFS2
>>> On Thu, Apr 12, 2007 at 11:51:27PM -0400, Peter Diamessis wrote:
>>>> Apparently, MPICH v1.2.7..15 is still being used at the cluster.
>>>> Our system
>>>> manager has made an effort to build it to make ROMIO compatible
>>>> with
>>>> PVFS2. Nonetheless, my problems persist. Would it simply be a
>>>> better
>>>> idea that they shift the whole cluster to MPICH2, which I assume
>>>> is more
>>>> naturally compatible with PVFS2 ?
>>> Hi Peter
>>> First, I'm glad you're using MPI-IO to its full potential and seeing
>>> good results. Second, yes, the PVFS v2 support in MPICH 1.2.7 is
>>> quite old: about 2
>>> years of bugfixes have gone into MPICH2-1.0.5p4.  It'd be great
>>> if you
>>> could run MPICH2 -- you might still find bugs but particularly for
>>> noncontiguous I/O we have fixed a number of issues. Now,
>>> complicating the matter is that v1.2.7..15 is a version of MPICH
>>> for the myrinet interconnect.  Your admin will know know if you are
>>> using GM or MX.  Let your administrator know you can build MPICH2
>>> with
>>> gm support by configuring MPICH2 with the --with-
>>> device=ch3:nemesis:gm
>>> flag.  You might also need --with-gm-include=/path/to/include/gm  if
>>> your GM headers are in a different location.
>>>> Sorry if I sound too ignorant but my I/O troubles have driven me
>>>> up the wall.
>>> This is not an ignorant question at all.  Thanks for sending in the
>>> report instead of just quitting in frustration.
>>> ==rob
>>> Rob Latham
>>> Mathematics and Computer Science Division    A215 0178 EA2D B059
>>> 8CDF
>>> Argonne National Lab, IL USA                 B29D F333 664A 4280
>>> 315B
