[MPICH] Disconnecting spawned processes after MPI_Intercomm_merge
James S Perrin
james.s.perrin at manchester.ac.uk
Tue Sep 26 12:02:47 CDT 2006
I'm following up to my earlier query about using forked processes in MPI . As
this was considered a no-no I've being trying to put together the appropiate
framework using spawned processes. Simply I want to start a set of spawned
processes and then end them (due to a 3rd party API forcing an exit) and keep
the parent processes running.
After searching online and looking at the MPI-2 spec it seems the use of
MPI_Comm_disconnect is not well documented. However I've got a simple example to
work, which just launches and closes the spawned processes once.
The problem occurs when I create an intracommunicator with
MPI_Intercomm_merge(). I've tried freeing and disconnecting from the new
intracomm but the child processes seem to be waiting for the parent to
MPI_Finalize(). How do I release the intracomm? Is this a bug or feature?
"Using MPI" implies that I might be better off using intercommunicators for my
"parallel-server, parallel-client" application so I guess I should explore this.
spawn_master.c
int main (int argc, char * argv[])
int no_exit = 1;
MPI_Comm inter_comm, new_world;
MPI_Init (&argc, &argv);
MPI_Comm_spawn("./spawn_worker", &argv[1], 1, MPI_INFO_NULL, 0,
MPI_COMM_WORLD, &inter_comm, errs);
MPI_Intercomm_merge(inter_comm, 0, &new_world);
// Let worker do its thing
MPI_Comm_free(&new_world);
MPI_Comm_disconnect(&inter_comm);
while(no_exit)
// go and do something else
MPI_Finalize();
return EXIT_SUCCESS;
spawn_worker.c
MPI_Comm parent, new_world;
MPI_Comm_get_parent(&parent);
MPI_Intercomm_merge(parent, 1, &new_world);
// Do something useful
MPI_Comm_disconnect(&parent);
MPI_Finalize();
Appologies for rambling but I kept coming across new bits of info as I was
writing this.
Regards
James
James S. Perrin, | email: james.perrin at manchester.ac.uk
Manchester Visualization Centre, | www.sve.man.ac.uk/General/Staff/perrin
Kilburn Building, The University, | tel: +44 161 275 6945
Manchester, England. M13 9PL. | fax: +44 161 275 6800/6040
"The test of intellect is the refusal to belabour the obvious" -Alfred Bester
