[MPICH] Forking exisiting mpi processes
James S Perrin
james.s.perrin at manchester.ac.uk
Wed Sep 20 08:55:14 CDT 2006
In our particular case the parent is only used to fork a child process on
demand, it doesn't need to make any MPI calls itself and so the forked child
process "can" assume it's identity. We've needed to use forking because a 3rd
party API we are using doesn't support stopping and restarting - when it stops
it exits! These processes weren't previously using MPI but the next version of
the software requires MPI communication with them.
Regards
James
Rusty Lusk wrote:
> This is likely to be a bad idea. Just for starters, you will now have
> two different MPI processes with the same rank. What does your
> application logic think about this?
> Regards,
> Rusty Lusk
> On Sep 20, 2006, at 1:27 PM, James S Perrin wrote:
>> Hi,
>> I'm looking for some details of what can and can't be done if a
>> running mpi process forks.
>> From a simple test program it seems, at least with MPICH, that
>> the child process inherits the mpi environment and credentials of
>> the parent and can make MPI calls as if it were the parent process.
>> The child process should simply exit on completion and only the
>> parent process should call MPI_Finalize. Child to child communication
>> is best done using a dedicated MPI_Comm, the same as working with
>> threads. However is thread support actaully required? Should
>> MPI_thread_init be called?
>> Regards
>> James
>> James S. Perrin, | email:
>> james.perrin at manchester.ac.uk
>> Manchester Visualization Centre, | www.sve.man.ac.uk/General/
>> Staff/perrin
>> Kilburn Building, The University, | tel: +44 161 275 6945
>> Manchester, England. M13 9PL. | fax: +44 161 275 6800/6040
>> "The test of intellect is the refusal to belabour the obvious" -
>> Alfred Bester
James S. Perrin, | email: james.perrin at manchester.ac.uk
Manchester Visualization Centre, | www.sve.man.ac.uk/General/Staff/perrin
"The test of intellect is the refusal to belabour the obvious" -Alfred Bester
