[MPICH] stuck in bcast
Geoff Jacobs
gdjacobs at gmail.com
Fri Oct 27 12:58:15 CDT 2006
Martin Kleinschmidt wrote:
> On Do, 26 Okt 2006, Rajeev Thakur wrote:
>> Is there enough memory allocated for the buffer?
> if (myid .eq. 0) then
> allocate(adiag(nsaf), ediag(nsaf), stat = ierr)
> if (ierr .ne. 0) stop 'allocation error in sigdire'
> (calculate ediag)
> endif
> if (myid .ne. 0) then
> allocate(ediag(nsaf), stat = ierr)
> endif
> c for testing if ediag is correctly allocated:
> do ia = 1, nsaf
> ediag(i) = i
> enddo
> c this is working up to nsaf=1495039
> do ii = 1 490 001 , 1 500 001
> call MPI_bcast(ediag, ii,
> $ MPI_double_precision, 0, MPI_Comm_World, MPIerr)
> write(*,*)'bcast success, ii=',ii
> enddo
>> If you can send us a small test program that demonstrates the error, it
>> would be useful.
> This is one of my problems: I have not yet been able to extract an
> example out of my code, which still produces the error.
> Maybe it depends on something, my code does before reaching the bcast,
> but I can't imagine what it might be...
Can you try this on a different compiler (I could help in this, if you
don't have access otherwise)?
Geoffrey D. Jacobs
Go to the Chinese Restaurant,
Order the Special
