[MPICH] "failed to ping mpd on "
Ralph Butler
rbutler at mtsu.edu
Tue May 23 12:17:33 CDT 2006
mpd will pick a port for you. But if you want to pick one yourself,
the -l (--listenport) option
supports that; see "mpd --help". Keep in mind that the MPI processes
will also need to
communicate and will need other ports.
On May 23, 2006, at 10:53 AM, hicham wrote:
> Thanks for your help, I've went thru the troubleshootin section
> found out that the mpd's were assigned to 127.0.0.1 rather than there
> ip address
> i haven't applied the patch,
> my concern now is to start mpd's on the two pc ( or more ) on a
> specific port and set a firewall allowin only this port and ssh
> hicham.
