[MPICH] Re: [MPICH2 Req #2520] mpdboot complains about "invalid port"
Ralph Butler rbutler at mtsu.edu
Fri May 12 12:14:15 CDT 2006
I forgot to copy the list on this:
Begin forwarded message:
> From: Ralph Butler <rbutler at mtsu.edu>
> Date: May 12, 2006 12:13:26 PM CDT
> To: Jerry Zhao <jzhao at Magma-DA.COM>
> Subject: Re: [MPICH2 Req #2520] mpdboot complains about "invalid port"
> You probably need to apply the attached patch to mpd.py in your
> installed code and the src if
> you may re-install later.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060512/d328171f/attachment.obj>
> On May 12, 2006, at 11:37 AM, Jerry Zhao wrote:
>> Hello, I don't know if this is the right email address to ask help
>> for running MPICH2, which our team just recently installed. If
>> not, would you please point me to the right direction?
>> I was able to start MPD on couple of machines one at a time so
>> that they can see and talk to each other. This was done by
>>     %> mpd &
>> couple of times on the two machines, respectively.
>> However, if I used mpdboot, I was running into problem of invalid
>> port info:
>> jzhao at opteron0151.magma-da.com-> mpdboot -n 2 -f ./
>> mpd.hosts.cluster --ncpus=2
>> mpdboot_opteron0151.magma-da.com (handle_mpd_output 373): from mpd
>> on opteron0152.magma-da.com, invalid port info:
>> Linux 2.4.21-20.ELsmp
>> 57015
>> 57015
>> Where my mpd.hosts.cluster file is:
>> If I specify more options of ?v and --debug, I would have:
>> mpd.hosts.cluster -v --debug --ncpus=2
>> debug: starting
>> running mpdallexit on opteron0151.magma-da.com
>> LAUNCHED mpd on opteron0151.magma-da.com  via
>> debug: launch cmd= /magma/acad/tools/mpich2-1.0.3/ch3_ssm/bin/
>> mpd.py   --ncpus=2 -e -d
>> debug: mpd on opteron0151.magma-da.com  on port 42355
>> RUNNING: mpd on opteron0151.magma-da.com
>> debug: info for running mpd: {'host': 'opteron0151.magma-da.com',
>> 'entry_host': '', 'ifhn': '', 'ncpus': 2, 'list_port': 42355,
>> 'entry_port': ''}
>> LAUNCHED mpd on opteron0152.magma-da.com  via  opteron0151.magma-
>> da.com
>> debug: launch cmd= ssh -x -n opteron0152.magma-da.com '/magma/acad/
>> tools/mpich2-1.0.3/ch3_ssm/bin/mpd.py  -h opteron0151.magma-da.com
>> -p 42355  --ncpus=2 -e -d'
>> debug: mpd on opteron0152.magma-da.com  on port Linux 2.4.21-20.ELsmp
>> 57022
>> 57022
>> Thanks a lot for your help,
>> Best Regards
>> Jerry Zhao
>> Principal Product Engineer, CDBU
>> Magma Design Automation, Inc.
>> 11921 North Mopac Expressway, #300
>> Austin, TX 78759
>> (512)651-1498 (phone)
>> (512)651-1520 (fax)
>> www.magma-da.com
