[MPICH] Problem with MPICH2 mpiexec with different executables
Matthew Siegel
siegelmatt at gmail.com
Thu May 4 20:55:17 CDT 2006
Hi all,
Thanks for the help in advance. Here's a detailed explanantion of the
problem I'm running in to.
A little background . . . I am running the latest MPICH2. I am using Rocks,
running on Xeon EM64T processors with Gig-E IP between the compute nodes.
Not completely relevant, but want to be complete.
I have written an app that has the following source code. It is a very very
simple because my real program which is quite complicated was not working,
and I figured that this app would work just fine.
#include <mpi.h>
#include <stdio.h>
int main(int argc, char** argv) {
MPI::Init(argc, argv);
printf("My app is running!!!!\n");
MPI::Finalize();
return 0;
I compiled it like this:
mpicxx -o my_app my_app.cpp
I start an mpd daemon on the the head node 'mpd &', and verify with
mpdtrace. So far so good.
I then execute the following:
mpiexec -l -n 1 ./myapp
and I get:
0: My app is running!!!!
and it quits. I then run:
mpiexec -l -n 4 ./myapp
and I get (as expected):
1: My app is running!!!!
3: My app is running!!!!
2: My app is running!!!!
OK, so this is good so far. Here's where things go awry...
I then run:
mpiexec -l -n 1 hostname : -n 1 date
and I get (again as expected):
0: <hostname>
1: <date>
Then I run (and here's where the problem is):
mpiexec -l -n 1 ./myapp : -n 1 hostname
and I get:
1: <hostname>
And NOTHING else! Just hangs FOREVER . . . have to hit CTRL-C to quit.
This continues regardless of the order that I run my app in, whether it's
the first or second on the line, it does not matter. Also, this is true
regardless of the "other" app that I am running, not necessarilly just
'hostname' or 'date', and does not matter how many nodes that I am using.
The real apps that I am trying to run both are using MPI and am trying to
pass data between the two processes. I have rebuilt MPICH2 multiple times,
and tried various configure options with zero luck.
Please help, this has become a showstopper for me.
Thanks!
Matt
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20060504/93e6237d/attachment.htm>
