[MPICH] Testing File open success
James S Perrin james.s.perrin at manchester.ac.uk
Fri Mar 10 05:12:18 CST 2006
	What is the correct way to test is a file has been opened successfully using
MPI_File_Open()? Currently I'm doing a fopen like test on the file handle:
if(fh)
// SUCCESS
} else {
// FAILURE
but have found that under linux files with spurious paths are coming back as
success using this method (file mode is RDONLY). Should I be testing the result
of MPI_File_Open() directly?
Regards
James
James S. Perrin,                   | email: james.perrin at manchester.ac.uk
Manchester Visualization Centre,   | www.sve.man.ac.uk/General/Staff/perrin
Kilburn Building, The University,  | tel: +44 161 275 6945
Manchester, England. M13 9PL.      | fax: +44 161 275 6800/6040
"The test of intellect is the refusal to belabour the obvious" -Alfred Bester
