[MPICH] mpich1 X mpich2 rsh troubles
    William Gropp
    gropp at mcs.anl.gov
    Thu Mar  2 08:19:14 CST 2006
At 08:02 AM 3/2/2006, Márcio Ricardo Pivello wrote:
>Hi
>I'm starting to work with mpich now, and I'm having some problems when
>running an application. I'm using mpich2-1.0.2p1 to compile a code which
>uses petsc 2.3.0, hypre 1.9.0b and ParMetis 3.1. The code has f77 and f90
>files. Compilation runs without any problem,  but when I try to run it i
>have the same error, no matters what machines are used in the cluster:
>-- Fatal error in MPI_Comm_size: Invalid communicator, error stack:
>MPI_Comm_size(110): MPI_Comm_size(comm=0x1, size=0xbfffe340) failed
>MPI_Comm_size(69): Invalid communicator
>rank 0 in job 4  no43_33215   caused collective abort of all ranks
>   exit status of rank 0: return code 13
This looks like the file was compiled with a a version of mpi.h or mpif.h,
or an MPI module, that belongs to a different MPI implementation.  Check
the compilation steps to make sure that the MPICH2 include paths are
used.  Also try using MPICH2 1.0.3, which is the current release.
Bill
>in this case, no43 is the hostname of the machine. It happens since the
>first host listed in the hosts file, and the process stops immediately.
>I'm using the following sequence to launch the application:
>mpdboot -np 4 -h hosts --rsh=rsh
>rsh <some_machine_listed_in_file_hosts>
>mpdrun -np 4 ../bin/linux-gnu-opt/SolverGP.x -ksp_gmres_restart 90
>-ksp_rtol 0.000001 -log_info -ksp_monitor -log_summary >& run-2p-b.log &
>What is the problem here?
>Thanks in Advance
>-Márcio Ricardo Pivello
>PS.: I tried to run this code with mpi1 1.2.6, but the code I'm trying to
>compile needs the library libmpichf90.a, which I didn't find in mpich 1.
>Is there any alternative for this library, or could I add this library to
>mpich1 libraries?
>Mechanical Engineer, MSc.
>LTCM and CFD Lab
>Mechanical Engineering School
>Federal University of Uberlândia
>Uberlândia - MG - Brazil
William Gropp
http://www.mcs.anl.gov/~gropp
