[MPICH] thanks RE: src node found for mpitest/io tests
    Liwei Peng
    liweip at windows.microsoft.com
    Fri Jun 30 12:29:42 CDT 2006
Thanks Rajeev.
I got the code. It is under mpich2 code base src\mpi\romio\test,
liwei
-----Original Message-----
Sent: Friday, June 30, 2006 10:08 AM
To: Liwei Peng; 'William Gropp'
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: src node found for mpitest/io tests
Those are in the src/mpi/romio/test directory in MPICH2 or
src/romio/test
directory in MPICH-1.
Rajeev
> From: Liwei Peng [mailto:liweip at windows.microsoft.com]
> Sent: Thursday, June 29, 2006 6:52 PM
> To: William Gropp; Rajeev Thakur
> Subject: src node found for mpitest/io tests
> Hi Bill,
> Thanks for the help.
> I couldn't find the test sources for mpitest\io posted on
> http://www-unix.mcs.anl.gov/mpi/mpich2/todo/runs/IA32-Linux-GN
U-mpd-ch3-
> 2006-06-27-22-00-testsumm.xml
> in the testsuite
> http://www-unix.mcs.anl.gov/mpi/mpi-test/downloads/mpich-test.tar.gz
> can you tell me where I can download them?
> Thanks,
> Liwei
> From: William Gropp [mailto:gropp at mcs.anl.gov]
> Sent: Wednesday, June 28, 2006 11:28 AM
> To: Liwei Peng
> Cc: Rajeev Thakur; mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] MPICH1 test error report: what's the # of
> processes?
> At 01:14 PM 6/28/2006, Liwei Peng wrote:
> >Hi,
> >The latest MPICH error report from web site
NU-mpd-ch3
> >doesn't show how many processes were used on most of the test cases,
> >e.g. sendrecv.
> >Can you give me a list of the # processes for each test case? Or tell
> me
> >where I can get them?
> Most of the tests just use two processes.  For the MPICH1 tests, the
> number
> of processes is embedded in the runtests file in each
> directory .  For
> MPICH2, the file "testlist" indicates how many processes for each test
> in
> the second token.
> Bill
> >Thanks,
> >Liwei
> William Gropp
> http://www.mcs.anl.gov/~gropp
