[MPICH] EOF from console
Matthew Fowler tjue1 at central.susx.ac.uk
Thu Jun 15 08:30:35 CDT 2006
Hi Philip.
The boards actually have two LAN interfaces. I tried bringing down the
2nd like you suggested, but I have the same problem.
Here is the output of mpdcheck -v, I get the same respective output from
all the boards im using:
# mpdcheck -v
mpdcheck -v
obtaining hostname via gethostname and getfqdn
gethostname gives  board01
getfqdn gives  board01
checking out unqualified hostname; make sure is not "localhost", etc.
checking out qualified hostname; make sure is not "localhost", etc.
obtain IP addrs via qualified and unqualified hostnames;  make sure
other than 127.0.0.1
gethostbyname_ex:  ('board01', [], ['10.9.10.1'])
checking that IP addrs resolve to same host
now do some gethostbyaddr and gethostbyname_ex for machines in hosts file
Does that look right to you? I cant see anything wrong.
Oh yes im using a good Netgear Fast Ethernet Switch (just a little 8 port)
Best Regards
Matthew
Philip Sydney Lavers wrote:
>Hello Mathew,
>How many LAN cards per board? If more than one try ifconfig down on the card that is not meant to be in the ring.
>Also check that hostname on each board is actually what mpd thinks it is.
>Also are using LAN hub or switch?
>regards,
>Philip Lavers
>---- Original message ----
>>Date: Mon, 12 Jun 2006 16:49:08 +0100
>>From: tjue1 at sussex.ac.uk
>>Subject: [MPICH] EOF from console
>>To: beowulf at beowulf.org, mpich-discuss at mcs.anl.gov
>>Hi list
>>Im doing some experiments on an embedded platform and am building a
>>Beowulf cluster from them. I have a unusual setup as the boards have
>>limited memory and i am using MPICH 2 (latest). The setup is a bit
>>strange as Python is accessable to the boards via an NFS mount.
>>I can start an MPD daemon on a single board with no problems. I can
>>also add a further three to the ring with no probs. Adding a fith
>>causes an error. (see below)
>>(im adding nodes manually rather than using mpdboot. When I get it
>>working manually I will get mpdboot working.
>>Heres the problem:
>>(from first board)
>>mpdtrace -l
>>board01_2048 (10.9.10.1)
>>I then add others into the ring as:
>>mpd -h board01 -p 2048 &
>>mpdtrace
>>board02
>>board01
>>I can continue to add boards until I try and add a 5th. When adding a
>>5th using the above method I get:
>>mpdtrace &
>>mpdtrace (mpdtrace 57): got eof on console
>>Jul 22 08:33:49 board05 python2.3: mpdtrace (mpdtrace 57): got eof on
>>console
>>I have to admit im baffled. Can anyone shed some light on this? If more
>>specific information will help please tell me.
>>Regards
>>Matthew
