[MPICH] MPI_Probe and thread
    Wei-keng Liao
    wkliao at ece.northwestern.edu
    Fri Jul 28 00:24:07 CDT 2006
I am testing if an MPI node can send message to itself, using MPI_Send and
MPI_Probe on 2 different threads. Below is the MPI program that creates a
2nd thread, then sends an integer to the thread. The 2nd thread calls
MPI_Probe, receives the message, and exits.
If MPI_Probe happens before MPI_Send, I found that the program will hang
due to the 2nd thread is blocked in MPI_Probe. That is, MPI_Probe is busy
waiting and will not release/yield to the main thread.
If I add a pthread_yield() or sleep(2) before MPI_Probe to ensure MPI_Send
occurs before MPI_Probe, the 2nd thread's probe will get the message and
exit successfully.
Is there a limitation on using MPI_Probe in multi-threading environment?
I am using MPICH-2.1.0.3 which is configured with multi-threading enabled.
Wei-keng
#include <stdio.h>
#include <stdlib.h>
#include <mpi.h>
#include <pthread.h>
int SELF;
/*----< thread_func() >---------------------------------------------*/
void* thread_func(void *args) {
     MPI_Status status;
     int        src = -1, msg;
     pthread_yield();
     sleep(1);
     printf("P%d (thread): thread started\n", SELF);
     MPI_Probe(MPI_ANY_SOURCE, MPI_ANY_TAG, MPI_COMM_WORLD, &status);
     src = status.MPI_SOURCE;
     printf("P%d (thread): MPI_Probe() MPI_SOURCE = %d\n", SELF, src);
     MPI_Recv(&msg, 1, MPI_INT, src, 0, MPI_COMM_WORLD, &status);
/*----< main() >----------------------------------------------------*/
int main(int argc, char **argv) {
     int       i, msg;
     pthread_t thread_id;
     MPI_Init(&argc, &argv);
     MPI_Comm_rank(MPI_COMM_WORLD, &SELF);
     pthread_create(&thread_id, NULL, thread_func, NULL);
     MPI_Ssend(&msg, 1, MPI_INT, SELF, 0, MPI_COMM_WORLD);
     pthread_join(thread_id, NULL);
     printf("P%d ( main ): 2nd thread joined ---- exit\n", SELF);
     MPI_Finalize();
     return 0;
