[MPICH] MPICH2 on campus network, problems with DHCP?
Nathan Moore
nmoore at winona.edu
Thu Jul 27 00:26:47 CDT 2006
Hello,
I've downloaded and compiled MPICH2 on a small cluster of PowerPC's
running linux (YDL 4.1). While I've been able to get mpd to run on a
single node, communication within the ring fails. The error I've
seen with mpdcheck follows,
[root at muscovey ~]# mpdcheck -l
Your fully qualified hostname seems to be set to 'localhost'.
This generally means that your machine's /etc/hosts file
contains a line
similar to this:
127.0.0.1 mybox1 localhost.localdomain localhost
You probably want to remove your hostname from this line and
place it on
a line by itself with your ipaddress, like this:
$ipaddr mybox1
Your unqualified hostname resolves to 127.0.0.1, which is
the IP address reserved for localhost. This likely means that
you have a line similar to this one in your /etc/hosts file:
127.0.0.1 $uqhn
This should perhaps be changed to the following:
127.0.0.1 localhost.localdomain localhost
On my campus network, IP addresses are assigned by DHCP. To my
knowledge, this precludes the sort of "normal" /etc/hosts file like
the following,
[root at muscovey ~]# cat /etc/hosts.novel
# Do not remove the following line, or various programs
# that require network functionality will fail.
199.17.152.135 muscovey.workstations.winona.edu muscovey
where 199.17.152.135 is found through ifconfig -a, and accordingly, I
seem to be stuck with an /etc/hosts like,
127.0.0.1 muscovey localhost.localdomain localhost
Is there a workaround that allows only hostnames to be specified?
Nathan Moore
Physics
Winona State University
AIM:nmoorewsu
