[MPICH] Possible Race condition between Test() and Cancel
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue Jan 31 11:30:27 CST 2006
If the request is completed by a test or wait, it is set to
MPI_REQUEST_NULL. See if adding an "if (request != MPI_REQUEST_NULL)" around
the MPI_Cancel helps.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of David Minor
> Sent: Tuesday, January 31, 2006 1:22 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Possible Race condition between Test() and Cancel
> There appears to be a problem with MPI_Cancel. At least under
> Red Hat 9
> with the the g++ 3.4.3 compiler.
> If you Cancel a completed receive request, you will get an
> MPI abort or
> seg fault.
> But if you Test() the request before calling cancel on it there is
> always the possibility that between the Test() and the Cancel() the
> request will be completed thus causing an abort.  What is the
> solution?
> Shouldn't Cancel() simply return an error if the request is already
> completed?
> My specific problem is:
> I'w waiting with WaitAll on a set of receive requests. I want to wait
> until either 1) They all complete or 2) another thread
> decides to cancel
> the requests.
> The problem is that the thread that cancels the requests has no way of
> assuring that it doesn't call Cancel() on an already
> completed request.
> Please advise,
> Regards,
> David Minor Orbotech
