[MPICH] Trying to build for Fedora 3
    Rajeev Thakur
    thakur at mcs.anl.gov
    Mon Jan 30 15:55:46 CST 2006
Try without --enable-g=all. I think there is some problem (bug) if that is
used along with --enable-threads.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> peter_raeth at juno.com
> Sent: Monday, January 30, 2006 3:07 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Trying to build for Fedora 3
> Am trying to build mpich2-1.0.3 from the AllSource
> distribution while following the installer's guide.
> The operating system is Linux Fedora 3 standard.
> Used the following configure and make commands. Make fails
> with compile errors due to missing structure members.
> Can someone tell me what I am missing?
> Thanks very much.
> Best,
> Peter.
> [root at optiquest mpich2-1.0.3]#
> /opt/mpich2/mpich2-1.0.3/configure
> -prefix=/opt/mpich2/mpich2-install --enable-echo
> --enable-strict --enable-error-checking=all
> --enable-error-messages=all --enable-timing=all
> --enable-threads=multiple:global_mutex --enable-g=all
> --with-thread-package=pthreads  2>&1 | tee configure.log
> [root at optiquest mpich2-1.0.3]# make 2>&1 | tee make.log
> . < snip from bottom of console >
> sock_wait.i:674: error: structure has no member named
> `pollfds_updated'
> sock_wait.i: In function `MPIDU_Socki_handle_write':
> sock_wait.i:732: error: structure has no member named `pollfd_events'
> sock_wait.i:732: error: structure has no member named `pollfds_active'
> `pollfds_updated'
> sock_wait.i:759: error: structure has no member named `pollfd_events'
> sock_wait.i:759: error: structure has no member named `pollfds_active'
> `pollfds_updated'
> sock_wait.i: In function `MPIDU_Socki_handle_connect':
> sock_wait.i:814: error: structure has no member named `pollfd_events'
> sock_wait.i:814: error: structure has no member named `pollfds_active'
> `pollfds_updated'
> make[7]: *** [sock.o] Error 1
> make[7]: Leaving directory
> `/opt/mpich2/mpich2-1.0.3/src/mpid/common/sock/poll'
> make[6]: *** [all-redirect] Error 1
> make[6]: Leaving directory
> `/opt/mpich2/mpich2-1.0.3/src/mpid/common/sock'
> make[5]: *** [all-redirect] Error 2
> make[5]: Leaving directory
> `/opt/mpich2/mpich2-1.0.3/src/mpid/ch3/channels/sock'
> make[4]: *** [all-redirect] Error 1
> make[4]: Leaving directory
> `/opt/mpich2/mpich2-1.0.3/src/mpid/ch3/channels'
> make[3]: *** [all-redirect] Error 2
> make[3]: Leaving directory `/opt/mpich2/mpich2-1.0.3/src/mpid/ch3'
> make[2]: *** [all-redirect] Error 1
> make[2]: Leaving directory `/opt/mpich2/mpich2-1.0.3/src/mpid'
> make[1]: *** [all-redirect] Error 2
> make[1]: Leaving directory `/opt/mpich2/mpich2-1.0.3/src'
> make: *** [all-redirect] Error 2
