[MPICH] Redirecting standard/error io
    David Minor
    david-m at orbotech.com
    Mon Jan  9 03:27:13 CST 2006
Yes I'm having a specific problem, redirecting didn't help. I'm spawning
mpiexec from an application with a simple command line interface. After
mpiexec is spawned it seems like the spawned process is eating some of
the stdin to my application. I need to execute commands numerous times
before they're read on the stin of my app. My current workaround is to
set up a pipe re=route st/in-out for mpiexec, but I miss most of the
error messages this way.
David
-----Original Message-----
Sent: Monday, January 09, 2006 1:39 AM
To: David Minor
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [MPICH] Redirecting standard/error io
At 02:40 AM 12/26/2005, David Minor wrote:
>In mpiexiec, is there a way to direct standard input to /dev/null
and/or
>a way to direct standard and error output to a file?
As Rusty mentions, this should work for mpd.  The gforker version of
mpiexec has a bug in the current release that sends both stdout and
stderr
to stdout, but you should be able to redirect stdout to a file or to
/dev/null .  For our nightly tests, we redirect stdout and stderr to a
file.  Is there a particular problem that you are having?  We'd like
this
to work just like it was any other Unix command.
Bill
>David Minor
>Orbotech
William Gropp
http://www.mcs.anl.gov/~gropp
