[MPICH] Specifying machinefile within MPI_Comm_spawn command
    Rajesh Sudarsan
    rajesh.sudarsan at gmail.com
    Thu Feb 16 19:12:12 CST 2006
Thanks Rajeev.  I followed the steps as directed and it worked.
Rajesh
Rajeev Thakur wrote:
> You need to pass an MPI_Info object with the key "host" and value set to the
> hostname. I believe that this is one per process. So if you need to spawn
> two processes, you need to call MPI_Comm_spawn_multiple, with count=2,
> array_of_commands={worker,worker}, array_of_maxprocs={1,1},
> array_of_info={"host""debug7","host""debug8"; ie 2 info objects with the 2
> hostnames.
> Let us know if that doesn't work.
> Rajeev
>> -----Original Message-----
>> From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Rajesh Sudarsan
>> Sent: Thursday, February 16, 2006 10:40 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [MPICH] Specifying machinefile within MPI_Comm_spawn command
>> Hi,
>> I am trying out a simple example using MPI_Comm_spawn command
>> in mpich2.
>> The command works fine and it spawns new processes without any
>> error. But I am not able to specify on which processor node
>> to spawn the
>> process. The only argument where I thought I could enter the node
>> information was MPI_Info argument in the MPI_Comm_spawn command. But
>> still the spawn command starts the new processes on arbitrary nodes.
>> I know that in the case of LAM/MPI, the node specification for spawn
>> process is given as a "appshcema" file using MPI_Info
>> argument. But the
>> same technique does not seem to work in mpich2.
>> I read the earlier posts in Jan 2006 on this similar issue, but the
>> solution posted suggested to use some flags with the mpiexec
>> command.
>> The code that I am using,  spawns new processes in every iteration. I
>> believe setting the flags will be effective only the first
>> time when the
>> process is spawned.
>> Has any one else faced a similar problem?
>> My current schema file for the spawn command looks like this.
>> debug7 -np 1 -wd /nfs/storage1/users/sudarsar/  worker
>> debug8 -np 1  -wd /nfs/storage1/users/sudarsar/  worker
>> debug7 and debug8 are the nodes where I want to spawn new processes
>> using the spawn command.  "np" specifies the number of processes to be
>> spawned on each node. "wd" specifies the working directory.
>> And the last
>> argument gives the executable name.
>> I would really appreciate any kind of help.
>> Regards,
>> Rajesh
>> <http://groups.google.com/group/comp.parallel.mpi/browse_threa
>> d/thread/3a3d738528ee2147?hl=en#>
